Re: Sub frame connectors
[Re: roadrunninMark]
#1714720
12/28/14 10:33 PM
12/28/14 10:33 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Would bolt on aluminum work as well instead of steel? I know they can be heavy, was thinking if you were going to make them, what about aluminum?
You could but for the same size tubing, you'll have a subframe connector that is about half as weak (depending how the metal is prepped). Not only that, but generally aluminum cost more than steel. Even butting to dissimilar metals next to each other is generally not preferred.
[Re: TC@HP2]
#1714725
02/26/15 01:51 AM
02/26/15 01:51 AM
Posts: 4,954 WI
Dcuda69
WI
Mopars are so bendy by this stage of their life that even simple 1x3 units welded to just the front and rear sub frames are a HUGE improvement over nothing. Are they the ultimate, no, but they are a big step in the right direction. Quite worrying about it and put them in.
This guy gets it. I spent $50 on materials and a couple hours making it fit(I am by NO means a fabricator)and they made $500 difference! Don't over think it...tie them together and done!! You'll be glad you did!
[Re: Supercuda]
#1714731
03/04/15 09:16 PM
03/04/15 09:16 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Anybody try these? <a href="" target="_blank"></a> US Cartools Bolt in Sub Frame Connectors It looks intriguing, albeit pricy....
Dan
Read this first
https://board.moparts.org/ubbthreads/showflat.php?Number=7904856
I've talked to them fairly recently and expressed concern about their previous history. I was assured things were on the up and up. With their eBay store and being able to pay with PayPal, buyers should be fairly covered going that route.
Their Ebody chassis stiffening package is tempting..Chris Lewis is whom I was speaking with.
[Re: GoodysGotaCuda]
#1714732
03/04/15 09:21 PM
03/04/15 09:21 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Well, I dunno if they took care of the guy in the linked thread, but I felt the OP needed to know what he might be getting into.
[Re: Supercuda]
#1714733
03/04/15 09:22 PM
03/04/15 09:22 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yep, no doubt. I haven't spent any money with them, so I can't say one way or the other.
#1714734
03/04/15 11:10 PM
03/04/15 11:10 PM
Posts: 751 Saint Peters, MO
Brian
Saint Peters, MO
I've installed the entire chassis stiffening kit on my Duster. No issues with the purchase or installation.
1971 6.1 Gen III Hemi Duster
#1714735
03/20/15 08:47 PM
03/20/15 08:47 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Ordered Sunday, showed up today.
