Re: caltrac
[Re: 68cuda440]
#1714468
12/24/14 02:33 AM
12/24/14 02:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The sliders are nice.. just keep them clean.. what MOST people forget is the rubber bushings on old cars are hard and tend to bind up.. if you run shackles the old bushings can cause issues.. they can bind then snap free.. chassis's dont like to be upset.. thats part of the reasons that people really like the sliders.. they put a new item on the car that isnt binding... plus the sliders lower the back of the car and in most cases that helps on traction (gets the CG down a little more so its easier to get the front over the CG point)... but if people would just lube the rubber points now and then it would help
P-Body dude... I have Caltracs and Caltrack mono-leafs. I have brand new rubber bushings in my shackles. What would changing to sliders do for me? How much maintenance will I have to do on them to keep them working?
-Michael
If you keep the rubber bushings lube they are fine.. the sliders usually lower the back of the car about 1 1/2"... that can help the launch... keeping them clean is just that.. spray them down with lube once in a while... by the way I dont care to be called dude.. its just a thing ![](/ubbthreads/images/graemlins/wave.gif)
Re: caltrac
[Re: MR_P_BODY]
#1714469
12/24/14 02:46 PM
12/24/14 02:46 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
the sliders usually lower the back of the car about 1 1/2"/quote]
Depends where you put them. I mounted mine on a plate right next to the frame rail. Exact same ride height. If you had an inboard spring kit, they would actually raise the car slightly.
Re: caltrac
[Re: lockjaw-express]
#1714472
12/24/14 07:57 PM
12/24/14 07:57 PM
Posts: 861 lancaster,california
johnnycuda
The arrow on the Calvert sliders points forward, with the car at rest, spring bolt should be a little more than half way to the rear of the slot.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
