Page 2 of 3 1 2 3
Re: caltrac [Re: Thumperdart] #1714465
12/23/14 05:26 PM
12/23/14 05:26 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I tried 002, and 003 SS springs with Caltracs in 1999. Didn't work. The bump valving needs to be pretty stiff, or it will wheelhop like you won't believe. I remember thinking "my overrunning clutch is dieing", as the yoke pounded the floor pan. That was with QA1's set below 50%. That was running 1.45 60's, with 5800 flash.
Re: caltrac [Re: cesar perez] #1714466
12/23/14 05:50 PM
12/23/14 05:50 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I'm using Caltrac bars, mono leafs and QA-1 single adjustable shocks. Stock rear shackles with NEW rubber bushings.
No issues, set the preload (and pretty much forget it) and use the shock adjustment on a given day for track conditions.
Re: caltrac [Re: MR_P_BODY] #1714467
12/24/14 02:19 AM
12/24/14 02:19 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
The sliders are nice.. just keep them clean.. what
MOST people forget is the rubber bushings on old cars
are hard and tend to bind up.. if you run shackles
the old bushings can cause issues.. they can bind
then snap free.. chassis's dont like to be upset..
thats part of the reasons that people really like
the sliders.. they put a new item on the car that
isnt binding... plus the sliders lower the back of
the car and in most cases that helps on traction
(gets the CG down a little more so its easier to get
the front over the CG point)... but if people would
just lube the rubber points now and then it would help
P-Body dude... I have Caltracs and Caltrack mono-leafs. I have brand new rubber bushings in my shackles. What would changing to sliders do for me? How much maintenance will I have to do on them to keep them working?
-Michael
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: caltrac [Re: 68cuda440] #1714468
12/24/14 02:33 AM
12/24/14 02:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
-Michael
If you keep the rubber bushings lube they are fine..
the sliders usually lower the back of the car about
1 1/2"... that can help the launch... keeping them
clean is just that.. spray them down with lube once
in a while... by the way I dont care to be called dude..
its just a thing
Re: caltrac [Re: MR_P_BODY] #1714469
12/24/14 02:46 PM
12/24/14 02:46 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
1 1/2"/quote]
Depends where you put them. I mounted mine on a plate right next to the frame rail. Exact same ride height. If you had an inboard spring kit, they would actually raise the car slightly.
Re: caltrac [Re: dizuster] #1714470
12/24/14 03:24 PM
12/24/14 03:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
1 1/2"/quote]
My ride height didn`t change much ether since I lowered the rear shackles years ago when I moved the springs in and tubbed it.
Re: caltrac [Re: dizuster] #1714471
12/24/14 07:50 PM
12/24/14 07:50 PM
Ohio
lockjaw-express Offline
Ohio
Dizuster,
I am looking at the direction of your Calvert spring slider, and I have mine where the "Arrow" that is cut into the top of the slider mount is pointing forward...did I install mine backward?
Thanks for the help.
Mark
Re: caltrac [Re: lockjaw-express] #1714472
12/24/14 07:57 PM
12/24/14 07:57 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
The arrow on the Calvert sliders points forward, with the car at rest, spring bolt should be a little more than half way to the rear of the slot.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: caltrac [Re: johnnycuda] #1714473
12/24/14 08:15 PM
12/24/14 08:15 PM
Ohio
Ohio
Johnnycuda, Thank you, and I have mine mounted correctly...big relief!
I will try my SS Springs first, and if they don't work out, then I will get the Mono-leafs...I was worried that the Monos would be too stiff for the street, but then again, I don't really drive the car on the street that much.
Re: caltrac [Re: lockjaw-express] #1714474
12/24/14 10:15 PM
12/24/14 10:15 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
1 or 2 of the front leafs may be wider than the stack so you just file/grind to fit the cal trac travel.
Re: caltrac [Re: johnnycuda] #1714475
12/24/14 10:41 PM
12/24/14 10:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
There`s an arrrow? My directions said nothing about arrows........... My bad, Calvert sliders............
Re: caltrac [Re: lockjaw-express] #1714476
12/24/14 10:47 PM
12/24/14 10:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been drivin w/em for years just set shocks on softest setting, take away pre-load and go...............
Re: caltrac [Re: MR_P_BODY] #1714477
12/25/14 02:24 AM
12/25/14 02:24 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
its just a thing
Thanks... Mike...
Re: caltrac [Re: lockjaw-express] #1714478
12/25/14 03:52 PM
12/25/14 03:52 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Dizuster,
Mark
I have the speedway motors sliders. No forward/rearward on them.
They are cheap too...
http://www.speedwaymotors.com/Speedway-Heavy-Duty-Chrysler-Type-Leaf-Spring-Sliders,5817.html
Re: caltrac [Re: dizuster] #1714479
12/25/14 03:58 PM
12/25/14 03:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Same here..............
Re: caltrac [Re: Leigh] #1714480
12/25/14 09:21 PM
12/25/14 09:21 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I tried the Cal-Trac and SS spring combo and there was a violent confrontation between the two that I'm sure is not healthy on an automatic transmission.There could possibly be a shock package that might tame it down but then you would be close to the same money for the mono's
Gus
64 Plymouth Savoy
Dana 60
Re: caltrac [Re: fourgearsavoy] #1714481
12/25/14 09:57 PM
12/25/14 09:57 PM
Ohio
Ohio
Well, I am now sold on the Mono-leafs, and will order them next week, and will not even try to get the SS springs to work.
Thank you for all of the advice!
Mark
Re: caltrac [Re: lockjaw-express] #1714482
12/25/14 10:02 PM
12/25/14 10:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mark
Like anything else, once you understand how it works you`ll be way happier.
Re: caltrac [Re: Thumperdart] #1714483
12/28/14 01:05 AM
12/28/14 01:05 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I also tried that combo on my dart . ss springs and caltrac bars. I tried every adjustment possible over 4 or 5 trips to the track.
It doesnt work !
even got John Calvert on the phone for a few tips. He also told me the Mono leaf has a much higher spring rate than the ss spring.
Re: caltrac [Re: 493_DART] #1714484
12/28/14 01:14 AM
12/28/14 01:14 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
We added Cal Tracs to worn out SS springs once on a low 11 sec car. Car was instantly dead on in 60'/ET, EVERY pass. The SS springs were way worn and the car was all over the place on 60' and thus ET.
Later we, added the mono's just to lower the ride height and nothing changed. 60'/ET still the same, albeit as I said before deadly consistent.
Maybe our deal was different at our (lack of) power at that time???
Page 2 of 3 1 2 3
