Re: SRT Hellcat wreck
[Re: not_a_charger]
#1714170
01/11/15 01:14 PM
01/11/15 01:14 PM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
The bottom line is that stupidity, recklessness, and lack of driving skill are all covered by your insurance policy.
Yes!!!
[Re: gdonovan]
#1714173
01/11/15 05:17 PM
01/11/15 05:17 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
insurers can't access the black box, can't pull a fluid sample from any of the vehicle systems, etc...without the owner's permission.
While this is true, like I said if someone has access to the car and keys at the body shop who is to stop them? Not the body shop owner who wants to keep that sweet, sweet insurance job money flowing in the door.
No one would be the wiser.
Not likely 1)Body shops usually are not equipped with scan tools. They normally sublet having modules reflashed/reprogrammed. 2) Crash data isn't something you can pull up with a code reader, I doubt it's available at a normal dealer level access, but OE at minimum. 3) If the Insurance Co wanted the data they could get it, either via a subpoena, or access it after they total it without any marginally legal shenanigans.
[Re: keyser soze]
#1714177
01/11/15 09:20 PM
01/11/15 09:20 PM
Posts: 198 Hershey, PA
73MagDuster
Hershey, PA
I have 2 Crash Data Retreival (CDR) machines at work. That is the only way to read most Event Data Recorders "black boxes" in cars. The only reason to have a CDR is to do accident investigation. Almost nobody except police and independent reconstruction firms have one. The full kit is about $8k and software runs about $1200 a year.
They are NOT mandated by the Feds. In 2013 the Feds made a minimum list of data a company had to store IF THEY CHOSE TO HAVE AN EDR.
Suprisingly some high end vehicles like BMW and Benz only started putting these in cars recently. GM started in the mid 90s.
Chrysler does have one of the more comprehensive data streams in theirs, including tire pressures and steering wheel angle.
Most EDR data is stored in the Airbag control module. There are some Fords that also save info in the PCM.
[Re: gdonovan]
#1714178
01/11/15 09:26 PM
01/11/15 09:26 PM
Skeptic
The Pale Blue Dot
I wrote "Not Likely"- Not Impossible I just dove down the rabbit hole and discovered that cars/light trucks can be accessed by the Bosch CDR tool, GM cars and trucks have the most coverage, back to 1994. Before vehicles built pre 9-2012 it's a crap shoot as far as how much data there is or how to get it. This is the latest release software and supported vehicles. Quote:
Who is saying shenanigans? Could be as innocent as asking the body shop for access to a vehicle that is wrecked so an appraisal can be performed.
There is nothing innocent about it, unethical at best. I still call shenanigans. The data would be useless in a legal case without a subpoena. If the car is totaled, then in Ins Co owns the car and has every right to access the modules.
[Re: 73MagDuster]
#1714179
01/11/15 09:41 PM
01/11/15 09:41 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
73MagDuster:
Where does your machine plug into: the OBD port, or directly to the EDR?
Mo' Farts
Moderated by "tbagger".
[Re: gdonovan]
#1714181
01/11/15 11:03 PM
01/11/15 11:03 PM
Posts: 19,918 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
The data you're referring to isn't accessible with the typical hand-held scanner. Plus, no insurance company is going to waste money on a ridiculously expensive piece of equipment that their appraiser is unlikely to ever need or utilize. THEY DON'T CARE if you were drunk, speeding, etc...all of that is covered by your insurance. It doesn't get the insurance company off the hook at all. Even if the insurer did as you suggest, they wouldn't be able to use the info anyway, since it would've been obtained illegally.
Earning every penny of that moderator paycheck.
DBAP
[Re: gdonovan]
#1714184
01/11/15 11:53 PM
01/11/15 11:53 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Does this $8K? tool delete the info also?
