Page 2 of 3 1 2 3
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: rattler] #1712041
12/18/14 11:39 PM
12/18/14 11:39 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Perfect... Keep us posted...
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 69dart] #1712042
12/21/14 12:32 AM
12/21/14 12:32 AM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
For ease of reading I'm just going to keep updating the original post. That way all the data and pictures will be at the "top"
I'm also looking for a 6.1 block. If anyone happens to know where one is for sale please email me.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712043
12/21/14 01:43 AM
12/21/14 01:43 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Great post! I'm looking forward to see how this turns out. If you can afford an aftermarket case, the Reid is much nicer than the JW junk. I'm making the change as soon as I can afford it.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712044
12/21/14 02:28 AM
12/21/14 02:28 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Here's the trans. A powerglide w/straight cuts and a pro brake. This is the biggest hold up in the project right now. I ordered a JW Ultra Bell for it 3 weeks ago and it was supposed to be delivered 2 weeks ago. Now I am told it won't ship until the 2nd week in January
If anyone has a JW Ultra Bell for a glide to a small mopar or Gen III Hemi PLEASE let me know.
I went through the same deal with JW for a BB to pg bellhousing. I come to find out the old design had major issues and they were redesigning it. After some calling I decided on a much better solution with a mid-plate adapter from Coan.
http://www.coanracing.com/Catalog.asp?ProductDetail=1923
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 451Cuda] #1712045
12/21/14 03:43 AM
12/21/14 03:43 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The only problem was that this harness was not designed to work with the MAP sensor on a truck intake manifold. But who in their right mind would run a truck manifold on one of these anyway! I'll be swapping out to a car 5.7 intake and eventually a 6.1 intake. The MAP sensor wire will then work without issue.
I thought I had read somewhere that the truck intake was actually the best stock one for power.
If the engine doesn't have MDS it will be pre 06 if it's a truck engine.
Kevin
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: Twostick] #1712046
12/21/14 02:29 PM
12/21/14 02:29 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The 70 bee.. did they change over to the complete front end from a strut car? That would be interesting to see. I'm selling all my engines to build a gen 3 myself and will be watching!
You're not that far from me either.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712047
12/21/14 02:58 PM
12/21/14 02:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I didn't get a T-shirt with mine
Mopar to the bone!!!
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 72Swinger] #1712048
12/21/14 03:24 PM
12/21/14 03:24 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
you're going to want to turn that thing around, the usb port is on the other side.
i have perfected the efisource install.lol.
also if you're going to use the megasquirt to control your cooling fan,( highly recommended) you will want to run the fan wire through the harness before you get to far into your install. the efisource directions on the pin location are all the directions you will need.
i have an awesome tune up for anyone running eagle heads on an early engine with a decent camshaft too.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: mcat4321] #1712049
12/21/14 04:05 PM
12/21/14 04:05 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I will probably rotate it 90 degrees counterclockwise.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: Twostick] #1712050
12/21/14 04:21 PM
12/21/14 04:21 PM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
Kevin
The 6.1 intake is by far the best stock intake for power.
If it is MDS I will be switching out those lifters when I swap the cam.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: cudaman1969] #1712051
12/21/14 04:23 PM
12/21/14 04:23 PM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
It is a complete swap - front and rear. If you need any detailed pics let me know and I'll snap some for you - as long as I can get them with the car on the dyno
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712052
12/24/14 03:08 PM
12/24/14 03:08 PM
MN
hemidup Offline
hemidup  Offline
MN
Kevin
It'll be interesting in seeing your dyno results between the 2 intakes. I dyno'd a 418 stroker using an 05 the truck intake and SRT8 6.1 intake. Even with the port mismatch both those intakes preformed almost identical to the point when I overlayed the 2 graphs I couldn't tell which was which.
Jerry Williams.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: hemidup] #1712053
12/24/14 04:09 PM
12/24/14 04:09 PM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
That's interesting. Was there an aftermarket cam in the engine you tested? If so, what lift and duration?
What heads were on the engine? Since you mentioned port mismatch I am assuming old style 5.7 heads?
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712054
12/24/14 05:08 PM
12/24/14 05:08 PM
MN
hemidup Offline
hemidup  Offline
MN
Yes, 5.7 heads. The cam was .578/.588 231/236 @ .050" 114+4
Jerry Williams.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: hemidup] #1712055
12/28/14 03:35 PM
12/28/14 03:35 PM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
I'm going to blame the mismatched ports for the 6.1 intake as the reason you had the results you did.
The stock "old style" 5.7 heads flow a respectable amount of air and at a high velocity in comparison to what we are used to with the B/RB, Zeeker or Indy heads. However, with the availability and pricing of 6.1 heads plus the additional flow and direct match for the 6.1 and Drag Pack intake the old 5.7 heads are only worth their weight in aluminum. And with the reasonable cost of the Apache (6.4) heads the 6.1 heads are even becoming less valuable. And now with the availability of the Thitek heads (which I sell) for a few extra dollars you can have the best head currently available.
I don't know if my cable driven throttle body adapter will work with the truck intake. If it does I will test both the truck and car 5.7 intakes. I sold the adapter plates I had sitting here for years so I won't be putting the 6.1 intake on the 5.7 heads. I do have some 6.1 heads that I plan on swapping onto the 5.7. At that point I'll test the 6.1 intake (and maybe a Drag Pack if I can find a loaner or buy one cheap
Still waiting on my JW bell housing
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712056
12/28/14 06:02 PM
12/28/14 06:02 PM
MN
hemidup Offline
hemidup  Offline
MN
For dyno purposes I gutted a throttle body so the blade was free to move then fabbed up a bracket to the blade gear for a throttle cable. Didn't look pretty, but was functional.
Jerry Williams.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: hemidup] #1712057
12/30/14 03:09 PM
12/30/14 03:09 PM
Canada
onig Offline
onig  Offline
Canada
What vehicle or engine did that LS throttle body come off of?
Does it bolt right in or is an adapter needed?
Will that LS throttle body bolt on to a 6.1 manifold?
69 Dart
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: onig] #1712058
12/30/14 03:18 PM
12/30/14 03:18 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I know that fast has a hemi to lsx Tb adapter plate. You can use any FAST style or Nick Williams cable drive throttle body.
I've got a BBK hemi Specific 80mm 1791 on my 6.1 intake.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: onig] #1712059
12/30/14 03:31 PM
12/30/14 03:31 PM
Portersville, Pa
1badx Offline OP
1badx  Offline OP
Portersville, Pa
The TB is off of an LS1 vehicle. It will not bolt directly to any Gen 3 Hemi manifold. It does require an adapter plate. I have several "prototype" adapter plates that I have tested and will be using one of those. There is also a company making direct bolt on cable driven throttle bodies that I will be selling once I test and verify functionality.
Re: Gen III Hemi - From Junkyard to Dragstrip [Re: 1badx] #1712060
12/30/14 03:57 PM
12/30/14 03:57 PM
Canada
onig Offline
onig  Offline
Canada
Thanks, good to know.
69 Dart
Page 2 of 3 1 2 3
