Re: World cast iron 4.5 bore hemi block
[Re: Canam800]
#1711179
12/15/14 09:41 PM
12/15/14 09:41 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I have a world hemi block cast iron 4.49 rough bored new never used that I bought a few years ago. Was thinking of going aluminum instead. How much do you think my block is worth? Just trying to see if its worth trying to go aluminum
Thanks Brandon
They cost between 2800-3000, when they're available. They're not available right now, so up to you.
[Re: fastmark]
#1711181
12/15/14 11:00 PM
12/15/14 11:00 PM
Posts: 7,545 Minnesota
Hemi_Joel
Minnesota
I would think you could get 3500ish. At least I see them advertised for that. How available are aluminum blocks @ $5000?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1711182
12/15/14 11:13 PM
12/15/14 11:13 PM
camastomcat
Salt Lake City
That depends on what options you are looking for and what machine work you are willing to do. The only one priced in that neighborhood is HP Performance and not sure what the availability is. The Indy at that price is rough......very rough. They advertise $4399 but they need a lot of work.
[Re: camastomcat]
#1711183
12/15/14 11:37 PM
12/15/14 11:37 PM
I just sold my mega siamese block for $3500 and now waiting for an aluminum one. Mine was +.250 on all cylinders
[Re: fastmark]
#1711185
12/16/14 02:37 AM
12/16/14 02:37 AM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
When I built a mopar siamesed bore hemi block,I started at 521 inches with a 4.5 stroke. My builder at the time{RIP} Lou Vignogna tod me I would make more power with the iron block,,,,,,,,,I have iron
[Re: Airwoofer]
#1711187
12/16/14 04:36 PM
12/16/14 04:36 PM
Hemi_Joel
Minnesota
What is the difference between a RB and a Hemi block?
The Hemi block comes with a gold necklace and a dinner jacket.
Plus the Hemi block has a provision for the additional head studs.
[Re: Airwoofer]
#1711188
12/16/14 05:26 PM
12/16/14 05:26 PM
camastomcat
Salt Lake City
They have different head mounting locations.
[Re: camastomcat]
#1711189
12/17/14 03:53 PM
12/17/14 03:53 PM
DaytonaTurbo
Manitoba, Canada
Clearance for the exhaust pushrods is the biggie.
[Re: DaytonaTurbo]
#1711190
12/17/14 09:56 PM
12/17/14 09:56 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
Id like iron block again. I have aluminum block worst decision I ever made. Horsepower robbing is aluminum is good for.
Shawn Jennings
[Re: camastomcat]
#1711192
12/17/14 10:21 PM
12/17/14 10:21 PM
Posts: 19,609 Las Vegas
Al_Alguire
Las Vegas
Based on what I have seen with my stuff I will stick with aluminum for sure. It MAY cost a little power but not that much. This aint the 80's anymore. My B1 makes good steam and the Predator is nearing completion and am sure it will do ok in it's aluminum block too.
[Re: camastomcat]
#1711193
12/17/14 10:30 PM
12/17/14 10:30 PM
572_dup2
Salina ks
Indy. Added more compression, took off 175lbs an it runs slower. lost over 6%. Talked to ring company at PRI show. He verified some blocks lose a lot more than others. Then called VP. Thought maybe was using wrong fuel. Told him my situation he verified to some blocks lose more than others.
Shawn Jennings
[Re: 572_dup2]
#1711194
12/17/14 11:03 PM
12/17/14 11:03 PM
Al_Alguire
Las Vegas
That would be my last choice for an aluminum block. I have seen more than one that just don't cut it on the power side. They also seem to "go soft" over time. Just saying.
[Re: Al_Alguire]
#1711195
12/17/14 11:12 PM
12/17/14 11:12 PM
572_dup2
Salina ks
It went soft when it started
Shawn Jennings
