Re: World cast iron 4.5 bore hemi block
[Re: Al_Alguire]
#1711196
12/18/14 12:09 AM
12/18/14 12:09 AM
Posts: 6,780 Alabama
Mopar-Al
Alabama
That would be my last choice for an aluminum block. I have seen more than one that just don't cut it on the power side. They also seem to "go soft" over time. Just saying.
Darn, I just did my Indymaxx block with B1's at 14.5 compression, so I could drop a little weight. I wasn't expectinng a serious HP loss. I hadn't dyno'ed my engine, but was still hoping to achieve 900-925 hp. Tracks are closed, so I cant get an approximate yet. I get my car back out of the chassis shop this week. I am shooting for a 5.40 or so. I am the only mopar there. I want to run with the quick 8 at our track
[Re: Mopar-Al]
#1711197
12/18/14 12:27 AM
12/18/14 12:27 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Moparal ,Where do you race at I would like to go sometime and meet you and check out your car? Glenn..........
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Mopar-Al]
#1711199
12/18/14 10:50 AM
12/18/14 10:50 AM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
Friend of mine bought same block month after I did. Our cars weigh the same have same compression an c.I. they run nearly the same too. He seen the exact gains I did ...nothing. Prepare yourself for disappointment.
Shawn Jennings
[Re: Mopar-Al]
#1711201
12/18/14 02:21 PM
12/18/14 02:21 PM
572_dup2
Salina ks
3500. Last 8 passes went 8.8s 152 with concrete filled mega block. I'm nowhere close to that now.
Shawn Jennings
[Re: 572_dup2]
#1711202
12/18/14 02:37 PM
12/18/14 02:37 PM
Posts: 1,303 Penna
70satelliteguy
Penna
"3500. Last 8 passes went 8.8s 152 with concrete filled mega block. I'm nowhere close to that now" Shawn was that still with 572 c.i. or larger ? What is the car currently running with the aluminum motor? I also was considering going from Mega block to Aluminum Mike
[Re: 572_dup2]
#1711203
12/18/14 07:52 PM
12/18/14 07:52 PM
Mopar-Al
Alabama
Same weather, pressures, and climate? I'm about 1000 lbs lighter than you are. I am impressed how you run with the super comp guys
