Re: Hub. honeing
[Re: racerx]
#1711098
12/15/14 06:31 PM
12/15/14 06:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I used a piece of 3/8 tubing with a slit in it and put 400 grit paper on it... rapped it around the tube till it was fairly big then put it in a drill motor... that was before I had a lathe
Re: Hub. honeing
[Re: Jerry]
#1711101
12/15/14 07:08 PM
12/15/14 07:08 PM
MR_P_BODY
I used a brake cylinder hone when I did my damper. also you can use a small ball hone. places like enco and kbctools etc sell them.
I busted my brake cyl hone trying to do it.. kept hanging up in the key way
Re: Hub. honeing
[Re: rickraw]
#1711103
12/15/14 07:41 PM
12/15/14 07:41 PM
MR_P_BODY
Brake hone is the best way. Make a wooden key to fit in the slot on the damper so u don't break the stones.
I didnt think of the wood spacer
Re: Hub. honeing
[Re: Monte_Smith]
#1711106
12/15/14 09:32 PM
12/15/14 09:32 PM
Posts: 75,106 A Banana Republic near you.
JohnRR
Decide how big you want it.........take it to your local shop and have them do it on a rod machine. It will be done before you can jury rig something.......plus it will be straight
Monte
Rod hone does it quick and easy.
Re: Hub. honeing
[Re: dogdays]
#1711108
12/15/14 09:43 PM
12/15/14 09:43 PM
JohnRR
Stuck mine in a 350 oven for a couple of hours, it went on with just a mild push plus a couple of taps.
R.
One could probably do that with a factory balancer on a factory crank , but aftermarket balancer , and a crank made by a diifferent company , I wouldn't bet on it .
Re: Hub. honeing
[Re: JohnRR]
#1711109
12/15/14 10:04 PM
12/15/14 10:04 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
R.
I have put them in water and boiled it for a few minutes to get enough expansion to get it on. I mentioned that to Fluidamper and they said that was probably OK, they just had never thought of it.
If you like drag racing, support your local track.
Re: Hub. honeing
[Re: CHAPPER]
#1711110
12/15/14 10:32 PM
12/15/14 10:32 PM
JohnRR
R.
What about getting it off though , heat or just sign of the cross and hope for the best ?
I have a magnetic bearing heater at work so I can get it up to 300-350 pretty effortlessly ...
Re: Hub. honeing
[Re: CHAPPER]
#1711111
12/15/14 10:37 PM
12/15/14 10:37 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
What you CAN do and what you SHOULD do are two totally different things. A certain amount of press is required. If you heat the thing hot enough, you can likely get it on even when the tolerance is way tight...........BUT, then you got to get it off at some point. If it is way tight, there are several scenarios. One you destroy a puller trying to get it off. Two, you drag metal out of the hub, or off the crank. One means you need a new hub. The other means you destroy the end of the crank. Sure, you can polish it off, but then you have drag marks and missing metal in hub or on crank snout. At that point the press is NEVER right, because you have incorrect surface area.
So.......WHAT TO DO?..........Check it..........fix it RIGHT
Monte
Re: Hub. honeing
[Re: JohnRR]
#1711113
12/15/14 11:56 PM
12/15/14 11:56 PM
CHAPPER
Belpre,Ohio
R.
Never had any problem getting them off using high pressure grease when installed. I'm not talking expanding it .005"+,,just maybe .001" or less with the 212* water heat. Just enough to go on easier with normal resistance than what it felt cold.
Re: Hub. honeing
[Re: racerx]
#1711116
12/16/14 11:22 AM
12/16/14 11:22 AM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
Did mine on a Sunnen honing machine.
Re: Hub. honeing
[Re: CHAPPER]
#1711117
12/16/14 07:39 PM
12/16/14 07:39 PM
JohnRR
R.
Your original post made it sound like you took a balancer that would not fit because of size and you heated to get it to expand and pressed it on ???
