Re: 71 cuda - 340 lost, what`s the best replacement?
[Re: Delta]
#1711059
02/28/15 04:11 AM
02/28/15 04:11 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
I'll probably be flogged for this, but 318's are probably more common in Europe, just as they are here on this side of the pond. A cheap (free?) 318 with a stroker crank installed is 390 cubic inches, no slouch & should rev up quickly just like a 340. And it can be dressed like a 340. Given the rarity of the car and it's collector value, you should long term look at finding a correct '71 340.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Delta]
#1711060
03/13/15 09:44 PM
03/13/15 09:44 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
I don't get all the " the 340 is much more expensive, so build a 360 statements". Fact is, if you look around at all, 340 blocks are easy to find and rarely more than 600-800 dollars. Even if you find a suitable 360 block for 100 dollars, in the whole scheme of the whole motor build you have maybe 500-700 dollars more money in the 340 build( cost difference of the block) Many times you can find a 340 short block with steel crank for not much if any more than the price I stated above for just the block.... Needing rebuilt. You pick up the quality steel crank that can take a lot of punishment and is a nice piece. For a car like yours, for very little difference in money I would i put another 340 in it( or a stroked 340)/416.... No brainer Edit.... Didn't notice I hadreplied to this thread months ago.... Lol
[Re: GO_Fish]
#1711061
03/16/15 04:00 PM
03/16/15 04:00 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
... A cheap (free?) 318 with a stroker crank installed is 390 cubic inches, no slouch & should rev up quickly just like a 340...
Not argumentative, but I've heard there was a problem with valve shrouding when you when with larger valves. Something about notching the cylinder wall tops. Can a 318 breath well enough to make power with a stroker crank?
[Re: Delta]
#1711064
03/29/15 01:09 AM
03/29/15 01:09 AM
GO_Fish
Maryland
I think the carb and intake manifold are different between '70-71. '70 still used the square bore AVS, and '71 was the first year spread bore Thermoquad? And I think the '71 was a one year carb before an improved version came in '72? Someone check me on this, ScottSmith Harms?
Scott B.
