Re: Mystery block (to me at least) [Re: WO23Coronet] #1710288
12/17/14 06:47 PM
12/17/14 06:47 PM
dogdays Offline
dogdays  Offline
Not all 230 blocks have these thick webs,, only the ones with the 1" high casting numbers.
R.
Re: Mystery block (to me at least) [Re: WO23Coronet] #1710289
12/17/14 07:51 PM
12/17/14 07:51 PM
Northern NJ
67440dodge Offline OP
Northern NJ
Does it have the thick main webs like 230 blocks are supposed to have? Can you show a pic?
If the pictures I've seen are of the thick main web blocks, then it looks like it does have them.
Re: Mystery block (to me at least) [Re: 67440dodge] #1710290
12/17/14 07:52 PM
12/17/14 07:52 PM
Northern NJ
Northern NJ
Here the side the throw was hiding
Re: Mystery block (to me at least) [Re: 67440dodge] #1710291
12/17/14 07:55 PM
12/17/14 07:55 PM
Northern NJ
Northern NJ
And no stampings on the oil pan rail.
Re: Mystery block (to me at least) [Re: 67440dodge] #1710292
12/17/14 09:49 PM
12/17/14 09:49 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the casting date tells you it's a thick web block , any 230 block before a certian date , I think it's 10/17/71 ??? is thick web.
There would be no stamps in that location, at least I have never seen it on anything built for the 69 and later model year on a Wedge block.
The VIN stamp you are looking for on the oil pan rail is on the SIDE of the block , pass side , just above the oil pan rail.
Re: Mystery block (to me at least) [Re: JohnRR] #1710293
12/18/14 08:43 PM
12/18/14 08:43 PM
Northern NJ
Northern NJ
I've never actually looked for a stamping on the oil pan rail before either, I saw it mentioned in the tech archive here http://www.moparts.org/Tech/Archive/motor/36.html and figured I'd give it a look. The VIN pad is definetely bare, no signs of anything ever stamped there.
Re: Mystery block (to me at least) [Re: 67440dodge] #1710294
12/19/14 12:23 AM
12/19/14 12:23 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
There were some 440 cast blocks that only were bored to 4.25. They were over the counter, not production. I heard they were originally planned to go to NASCAR racers that ran a RB wedge in the early 70s. A few Stock Eliminator racers found out about them and used them for the thick walls.
Re: Mystery block (to me at least) [Re: 67440dodge] #1710295
12/19/14 12:33 PM
12/19/14 12:33 PM
JohnRR Offline
JohnRR  Offline
If there is no VIN there you can be 90% sure that was not the original block in the car it came from , that is why it didn't go with it .
I never saw that page , glancing over it quickly I saw one error , I'm sure there are more .
