Re: Mystery block (to me at least)
[Re: WO23Coronet]
#1710289
12/17/14 07:51 PM
12/17/14 07:51 PM
Posts: 35 Northern NJ
67440dodge
Northern NJ
Does it have the thick main webs like 230 blocks are supposed to have? Can you show a pic?
If the pictures I've seen are of the thick main web blocks, then it looks like it does have them.
[Re: 67440dodge]
#1710292
12/17/14 09:49 PM
12/17/14 09:49 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
And no stampings on the oil pan rail.
the casting date tells you it's a thick web block , any 230 block before a certian date , I think it's 10/17/71 ??? is thick web.
There would be no stamps in that location, at least I have never seen it on anything built for the 69 and later model year on a Wedge block.
The VIN stamp you are looking for on the oil pan rail is on the SIDE of the block , pass side , just above the oil pan rail.
[Re: JohnRR]
#1710293
12/18/14 08:43 PM
12/18/14 08:43 PM
67440dodge
Northern NJ
I've never actually looked for a stamping on the oil pan rail before either, I saw it mentioned in the tech archive here http://www.moparts.org/Tech/Archive/motor/36.html and figured I'd give it a look. The VIN pad is definetely bare, no signs of anything ever stamped there.
[Re: 67440dodge]
#1710295
12/19/14 12:33 PM
12/19/14 12:33 PM
JohnRR
If there is no VIN there you can be 90% sure that was not the original block in the car it came from , that is why it didn't go with it .
I never saw that page , glancing over it quickly I saw one error , I'm sure there are more . ![](/ubbthreads/images/graemlins/Santa3.gif)
