Re: lighten up a little ! NSS K frame goes under the knife
[Re: BobsProFab]
#171034
12/20/08 07:17 PM
12/20/08 07:17 PM
Me next Bob!! poppaj
#171035
12/20/08 09:37 PM
12/20/08 09:37 PM
Posts: 1,413 Johnstown
69dart
Johnstown
Wow thats awsome work Bob!! The next time the engine is out of mine I'll be looking you up for sure. Thats 20-40lbs off the best spot in the car. Would adding a few holes to the K-member lighten even more without effecting the strength? My dad use to swiss cheese every part he put on his old 23-T Roadster.
Post deleted by Defbob
[Re: fullmetaljacket]
#171041
12/21/08 01:08 AM
12/21/08 01:08 AM
[Re: Blues_Cuda]
#171043
12/21/08 09:17 AM
12/21/08 09:17 AM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
Bob --
Would you be able to do one of these for a '73 Roadrunner?
any k frame can be lightened. just whether you want it to still retain the motor mounts or not as to what it weighs when its done.
[Re: rtstreet]
#171044
12/21/08 09:19 AM
12/21/08 09:19 AM
BobsProFab
sycamore,ohio
was there another thread with bob's new front end, and could someone post a link for me, please. Going to do cam's (my son) cuda soon the car is already 25.5 caged but still has all stock front.
do you mean my tube front steer front end.
[Re: dizuster]
#171047
12/21/08 11:39 AM
12/21/08 11:39 AM
BobsProFab
sycamore,ohio
How much of that weight was in just the motor mounts?...
Scott, the mounts them self (welded to k frame)are only a few lbs. removing the center section and de-ribbing it took alot of the weight out.
and also when you add in the weight of the motor mounts them self that bolt the motor to the k frame, out weighs a set of ears or lightened motor plate, so thats even more weigh to save. every thing starts adding up when you take everything into consideration.
ligthen the k frame draglink struts steering shaft loose the motor mounts = ET gain, as much as a 1/2 tenth
100 lbs. = 1/10 in ET
and getting the weight off where you need it off on a car thats limited to a small tire is the goal
theres so many ways to take weighed off switch to alum or Tit (if you can afford them ) bolts in certain places (bumper and fender bolts) ive even faced down castle nuts and drilled thru holes in bolts to help save weight its just how far you want to take it.
heres a pic of a lightened B body steering shaft. weighs less than 2 lbs. Bondo
