Re: TTI's for Borgeson Box
[Re: RylisPro]
#1709947
12/14/14 01:27 PM
12/14/14 01:27 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Only the bellhousing cares about tooth count. Starter cares only that its bolts line up.
Mopar to the bone!!!
[Re: Consulier]
#1709950
12/17/14 07:39 PM
12/17/14 07:39 PM
72Swinger
Nebraska
Wtf Wesley? They didn't even clear that Kubota garden tractor starter I showed above?
[Re: 72Swinger]
#1709951
12/17/14 08:19 PM
12/17/14 08:19 PM
Posts: 256 USA
Consulier
USA
If by Kubota you mean the 5.7 Ram Manual Trans starter recommended on TTI's page, than yes.
It is interesting that these actually hit the passenger side frame rail and they also hit the bellhousing on the passenger side. I'll give them a pass on the bell since it's a Quicktime, but the frame rail is pretty much a WTF. Even with the factory customizing they were no where close to clearing the Torsion Bars.
At this point I'm going to run the 2" and let them clearance themselves if necessary. Some point down the road I will look at it again, but I'm done spending money on this... again.
[Re: Consulier]
#1709952
12/17/14 08:44 PM
12/17/14 08:44 PM
72Swinger
Nebraska
I'm pulling for ya, I think I'm gonna definitely assemble my engine and trans and K member on the garage floor this go around.
[Re: dangina]
#1709955
02/01/15 11:38 PM
02/01/15 11:38 PM
72Swinger
Nebraska
Mine came from Modern Muscle on black Friday 2013. FREE shipping.
[Re: RylisPro]
#1709958
02/07/15 01:09 AM
02/07/15 01:09 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
Got my Doug's D4477R's today- $345USD. They may be only 1 5/8" tubes, but IMHO more quality looking than those TTI's. The smaller tube isn't going to hurt at my intended performance level. Besides, after reading the "Slick-Built Small Block" article in the April issue of Mopar Muscle, I've come to the conclusion that the less than 1% improvement they saw on that stroker (which would never be felt in the seat-of-the-pants) I'm a-gonna be happy with my buy...
2 Demons...no, not my kids!
[Re: 4speeds4me]
#1709959
02/07/15 01:18 AM
02/07/15 01:18 AM
72Swinger
Nebraska
My other complaint about the TTI'S is why put the o2 bungs on the outside of the collectors where rocks from the front tires can kill them?
[Re: 68cuda440]
#1709965
02/17/15 12:13 AM
02/17/15 12:13 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
I don't take credit for this little gem, I learned it on FABO, but I think Wade Uchoog is using one.
Does this little gem fit a 440? And will it spin one with 11.25:1 CR?
-Michael
Well the Mopar mini starter it is replacing was on my BB if that tells you anything lol.
OK - I Guinea pigged today... this starter DOES NOT fit a 440. Definitely not one with a Quicktime Bellhousing. Starter is going back to the parts house now... either sticking with the stock Dakota mini starter with about 1/8" clearance between the starter lug and the block, or going to the RobbMC unit in all its clockable glory.
Where is the interference? I bought one to go on my low deck, first thing I noticed was that one of the mounting holes is tapped. I was holding off on drilling it out, so I could return it. Right now I have to drop the K member and pull the master to get the header out. Then I'm dropping my pants for a set of TTI's ![](/ubbthreads/images/graemlins/eeek.gif)
