'99 TJ Front Axle Swap #1709768
12/11/14 11:48 PM
12/11/14 11:48 PM
Creedmoor, NC, USA
74Charger Offline OP
Creedmoor, NC, USA
Plan on removing the stock low pinion 30 with 3.07 and swapping in a high pinion 30 with 3.54 from an XJ. Will be re-gearing front to a 3.73 at same time to match rear-end re-gear to 3.73
Will I need a new carrier for front axle?
What other challenges are ahead?
Re: '99 TJ Front Axle Swap [Re: 74Charger] #1709769
12/11/14 11:52 PM
12/11/14 11:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Yes.
