Page 3 of 3 1 2 3
Re: Ram 2500 Cummins Value over the years . . . [Re: 70Cuda383] #1709158
12/13/14 10:35 PM
12/13/14 10:35 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
Rust ??? On my truck ??? HA HA HA . . . I have driven it TWICE in winter . . . each time, totally sprayed clean and tucked in nice warm garage !!! Way back when I got it, I put the 4wd rear wheel well inner liners on my truck, everytime I have washed it, sprayed underneath - looks like the day I brought it home from the dealer. I have replaced the factory lift pump with a FASS unit, and also have had the injector pump rebuilt . . . such is life. Everything else has been bullet proof on the truck. Only reason to even THINK about selling, is to consolidate some vehicles . . .but then again, the ones I have are all paid for. So even a touch of maintenance money every year, is still cheaper than getting a new truck.
How long will they last ??? All depends on the owner and the maintenance. I have a buddy that thinks I am nuts for changing oil & filter every 3k miles on my truck . . . but hey, it's my truck and I feel comfy having it serviced that way (by myself of course!!) . . .
Cheers,
Mark
Re: Ram 2500 Cummins Value over the years . . . [Re: gss] #1709159
12/13/14 11:18 PM
12/13/14 11:18 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
So the Cummins is typically good for well over 300,000 miles, but at what point does the rest of the truck start to deteriorate significantly. In other words, if you were looking at a used truck, what would be your cutoff point on miles?
Body is the best part of the truck.
210,000 miles on my '01 Off-Road above. Not a single rattle in that cab. The 2Gens are without question the best mix of mechanical simplicity and modern comfort.
The undisputed weakness in these trucks is the front axle. I still have the OEM track bar, steering linkage, tie-rod ends and ball joints. The hubs, outer u-joints and passenger-side axle seal are have all been replaced for the third time. I'd like to have a word with the Ram Manager that ok'd this Mechanics' delight, I just gone done working on it.......AGAIN!
The undisputed weakness in the Cummins department is the Meathead tuner bunch and their funny ideas about "cold" air kits and running 150hp chips. It taxes everything on the truck and literally lets in the biggest enemy to diesel: dirt. These Twits shouldn't be allowed anywhere near a diesel engine.
Mo' Farts
Moderated by "tbagger".
Re: Ram 2500 Cummins Value over the years . . . [Re: 70Cuda383] #1709160
12/13/14 11:21 PM
12/13/14 11:21 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I figure my 05 will start to rust sometime in the next 10 years. I am already planning a trip to Wa. state when that happens to pickup a complete gasser with a nice body, that will take care of the body problem. The rest of the drivetrain will just be maintenance, we don't get enough rust where I live to damage the frame.
Sheldon
Re: Ram 2500 Cummins Value over the years . . . [Re: Lugnutz] #1709161
12/14/14 03:33 AM
12/14/14 03:33 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
This one came for sale 4 years ago in Minneapolis, paid 8500.00 for it. Its almost the holy grail, 98 quad cab, 4x4, auto with the 12V Cummins. It has 181k on it and rust has started on the drivers side door and over the wheel wells which is standard for trucks in the rust belt. Not sure about non rust belt areas.
I have the same truck with little over 125K now, took me a long time to find it. Not really a rust belt here but near the ocean, bottom of drivers door and cab corners are starting to rust. I constantly get ask if it's for sale as its a rare model here.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Ram 2500 Cummins Value over the years . . . [Re: megajoltman] #1709162
12/14/14 03:46 PM
12/14/14 03:46 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
I have a 98 3500 dually auto 4x4 now with 205,000 miles that I bought out of Az in 2007 with the intention of keeping it for a very long time. It only tows to the races and doesn't have a spot of rust on it. I do long distance towing with it and don't like surprises so I've pretty much gone through the whole truck (except I haven't touched the engine)FASS, fancy trans and convertor, Pacbrake, new tires, brakes, hub and bearings etc etc... So last winter I came across an affordable diesel pusher motorhome and now I tow with that so the truck just sits here. I've tried to sell it and have it listed for the price of the parts I've put in it in the last year or two. And I'm not getting ANY bites. It's not hurting anything sitting here so I will just keep it.
Page 3 of 3 1 2 3
