BEST Brake Pads for 2011 Ram 1500? #1708957
12/10/14 02:56 PM
12/10/14 02:56 PM
Morningside
AdventurerSport Offline OP
waaaay out there in left field
Morningside
I'm getting ready to replace brake pads on my 2011 Ram, what does anyone recommend and suggest? Any suggestions appreciated, thank you!
Looking for the best possible quality!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: BEST Brake Pads for 2011 Ram 1500? [Re: AdventurerSport] #1708958
12/10/14 03:13 PM
12/10/14 03:13 PM
Ceramic get good reviews. You might do a bed in procedure if you want to go that far
Re: BEST Brake Pads for 2011 Ram 1500? [Re: RapidRobert] #1708959
12/10/14 03:31 PM
12/10/14 03:31 PM
Morningside
Morningside
"bed in procedure"? please explain
JS
Re: BEST Brake Pads for 2011 Ram 1500? [Re: AdventurerSport] #1708960
12/10/14 05:44 PM
12/10/14 05:44 PM
dogdays Offline
dogdays  Offline
Do a Google search, it will show up. You may want to start here:
http://www.tirerack.com/brakes/tech/techpage.jsp?techid=85
R.
Re: BEST Brake Pads for 2011 Ram 1500? [Re: AdventurerSport] #1708961
12/10/14 07:08 PM
12/10/14 07:08 PM
Central Ohio
BMChrysler68 Offline
Smarter than the average bear? I think not.
Central Ohio
I put Autozone (Duralast?) ceramics on my Magnum without doing a thing (to include resurfacing/replacing rotors). They were quiet with zero dust. No shimmy. No shake. Just smooth braking. I can't say that the techniques in the above article won't buy you a couple feet (I can't say that it will either), but I do my best to not come that close to hitting stuff/people.
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
Re: BEST Brake Pads for 2011 Ram 1500? [Re: AdventurerSport] #1708962
12/10/14 09:45 PM
12/10/14 09:45 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Save your rotors and put organic or semi metallic pads on.
Re: BEST Brake Pads for 2011 Ram 1500? [Re: AdventurerSport] #1708963
12/10/14 10:12 PM
12/10/14 10:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
JS
I drive the vehicle up a long hill(1/2 mile) and make sure I have good brake petal on the way up. Then I turn around and make at least 3 hard stops from 40 mph down to about 5mph hard and do it 3 times and the shoes and pads are bedded. IMO
Re: BEST Brake Pads for 2011 Ram 1500? [Re: Challenger 1] #1708964
12/10/14 10:56 PM
12/10/14 10:56 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I used Performance Friction Carbon Metallic on my diesel with good results and will probably use them on my new Ram when it needs brakes.
