Re: Frustrated - pro parts headers and 440 Rb w/ eddy 440 v
[Re: 340KID]
#1708775
12/09/14 11:52 PM
12/09/14 11:52 PM
Posts: 549 CT
340KID
CT
[Re: 340KID]
#1708777
12/10/14 12:01 AM
12/10/14 12:01 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
$675 and I will ship you my headers I told you to buy 2 months ago.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 340KID]
#1708779
12/10/14 12:05 AM
12/10/14 12:05 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Does the header line up right without the valve cover? Stack 4 headers gaskets together and BAM! fixed.
Mopar to the bone!!!
[Re: 340KID]
#1708781
12/10/14 12:26 AM
12/10/14 12:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Well if you dont want to send them back I would cut that tube about 3/4 of the way around at the flange and bow it out ... is that the same tube that off at the collector.. if it is then cut the whole tube off and slide the collector on and line it up at the flange with the proper angle at the VC and weld it back up... but I've done lots of headers
[Re: 340KID]
#1708784
12/10/14 12:42 AM
12/10/14 12:42 AM
MR_P_BODY
Yes same tube, I think it was welded wrong, it's the #1cylinder that comes down between 5 &7, it's not right on top and below !!
Thats what I thought... cut it off at the flange and put the collector on all 4 and line it up proper and weld it up.... 20 minutes and your done... then get them coated
[Re: MR_P_BODY]
#1708786
12/10/14 01:05 AM
12/10/14 01:05 AM
72Swinger
Nebraska
Some heat and a cheater bar no good idea??? No? Come on! No balls No babies!!
[Re: 72Swinger]
#1708787
12/10/14 07:43 AM
12/10/14 07:43 AM
Posts: 6,295 U.S.
moparniac
U.S.
I run those headers on -1s and I had issues on the passenger side. A couple of tubes needed reworked.
Mopar Performance
[Re: moparniac]
#1708788
12/10/14 12:41 PM
12/10/14 12:41 PM
MR_P_BODY
I'm surprised that they dont do a better job on the jig to improve this... it takes very little work to do it... you guys that have had issues SHOULD contact them and show some pics so they can improve the jig.. all the headers I built were built to a car so 95% of them I didnt need to build a jig
[Re: 72Swinger]
#1708789
12/10/14 12:47 PM
12/10/14 12:47 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
This would be me !
[Re: Airwoofer]
#1708791
12/10/14 01:03 PM
12/10/14 01:03 PM
MR_P_BODY
I have a set that I will mock up on my 540 with -1 heads before I put it in, maybe tonight 'cept it is COLD down here. When I bought them Bob said not to coat them cause they would need changing. Maybe this is what he meant.
Yep.. mock them up on the engine and see if they clear everything.. then you'll have to do the same thing in the car... THEN get them coated.. when I build headers I try to do it so its mech friendly.. so you can get to everything without loosening or removing them.. I also try to build them so they go in and out without lifting the engine or anything else... but the bottom line is you have to get them mounted up or they are useless (I wont even get into equal length and collector length)...... but if you BUY headers and run into problems you SHOULD contact the company with the issues and give them pics to show where the issues are.. if they never hear from the customer that there is a issue then they think all is good... one last thing... every set of off the shelf headers I have ever seen or worked on the collector is way too short... as a general number they should be 18" from the end of the pri tubes to the end
[Re: 340KID]
#1708793
12/10/14 05:01 PM
12/10/14 05:01 PM
Posts: 4,492 northern,Ohio,USA
Clanton
northern,Ohio,USA
How is the fit with the cover off?It should have room to check the rest of the fit. Not the best fix but if you grind/cut away enough of the pipe that hits just to use it and get things done and fix it after.A 3/8" dimple may work also and fix later.Just an idea. PS:I ran the #1 tube under the rest and it looks like you can adjust that pipe to do that if it will work for you.
