Re: Driveline angles
[Re: Cab_Burge]
#1707907
12/10/14 09:37 PM
12/10/14 09:37 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
The u joints don't know the difference in angles from left to right and from up and down, the rear U joint and tranny yokes will know when overly misaligned
stressed I would never have a upside down V angle (The pinion pointed up and the drivesahft pointed down) between the pinion angle and driveshaft angles when sitting still, NEVER
Since you are correct in stating the u-joint doesn't know left/right/up/down - here's a sloppy chart to show some scenarios. All are viewed from side and referenced to ground.
Top one is engine level, u-joint 4*^,(driveshaft 4* dn) u-joint 4*v, pinion level. Next is engine 2* dn, u-joints 2*^,(driveshaft 4*dn) u-joint 2*v, pinion 2*up. Next is engine level, u-joints 2*v, (driveshaft 4* up) u-joint 2*^, pinion level. Bottom is engine 2* dn, u-joints 4*v, (driveshaft 4* up) u-joint 4*^, pinion 2*up.
All scenarios leave the engine/trans and the pinion centerline parallel . Top 2 are typical street car - bottom 2 are more chassis/big tire oriented.
And again - these are UNDER LOAD scenarios - how much more the pinion needs to start out pointed down from these figures vary by suspension type - could be anywhere from 1-7*.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1707908
12/11/14 03:23 AM
12/11/14 03:23 AM
Posts: 43,326 Bend,OR USA
Cab_Burge
Why would anyone, epscially a drag or road racer want to set thier rear ends up like the bottom two are I would lower the pinion angle down so it had at least two or more degrees difference(than the drivshaft angles) at static and maybe move it down more after trying that, more is better sometimes to start with, epsecailly on leaf spring cars The pinion shaft will always try rotate up under acceleraton, correct ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Cab_Burge]
#1707909
12/11/14 04:10 AM
12/11/14 04:10 AM
Evil Spirit
Newport, Mi
Why would anyone, epscially a drag or road racer want to set thier rear ends up like the bottom two are These are dictated by the engine/trans installed height and the diameter of the tires - so would YOU raise the engine, or put smaller tires on to "correct" this? I would lower the pinion angle down so it had at least two or more degrees difference(than the drivshaft angles) at static and maybe move it down more after trying that, more is better sometimes to start with, epsecailly on leaf spring cars. READ where I said the figures were (Big words, sound them out) UNDER LOAD, and 1-7* additional pinion angle would be needed, according to suspension. Not to mention that the two lower examples would likely be big tire chassis cars that wouldn't likely have leaf springs. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
