Page 3 of 3 1 2 3
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704093
12/02/14 10:53 AM
12/02/14 10:53 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
VERY NICE!!
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704094
12/02/14 12:05 PM
12/02/14 12:05 PM
Az
Crizila Offline
Crizila  Offline
Az
Torque comparison
Wow! Minimal low end give-away. Awesome #"s without resorting to "exotic" parts. I have heard that 600HP is the magic # not to exceed for a stock small block? I have 3 E58 motors ( all are 1979 vintage ). I have sonic tested 2 of them and the wall thickness was very good on both blocks ( around .2 ). Is this indicative of the E58 motor or am I just lucky?
Fastest 300
Re: Small Block pump gas bracket engine [Re: Crizila] #1704095
12/03/14 01:29 AM
12/03/14 01:29 AM
Earth
Rob C Offline
Rob C  Offline
Earth
You can do more power than 600 on stock blocks BUt the machine work has to be the top of the cream perfect.
Check FABO on a thread addressing that very issue and see how many are routinely exceeding that power level and making use of it regularly.
Re: Small Block pump gas bracket engine [Re: Rob C] #1704096
12/04/14 12:55 AM
12/04/14 12:55 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Mine is a 408ci with 606 hp on the dyno
best 60ft is 1.30 sec and 6.40 1/8 mile...
I had fun all summer with no problems.....except for 1 Indy rocker arm in the very last pass of the season!!
'67 Barracuda 3000lbs
Page 3 of 3 1 2 3
