Page 1 of 3 1 2 3
Small Block pump gas bracket engine #1704053
11/27/14 07:38 PM
11/27/14 07:38 PM
Northern Indiana
Dunnuck Racing Offline OP
Northern Indiana
Thought I would share some of my personal bracket engine I'm finishing up.
I used a BPE rotating assembly in my old block, .040 over 360 block. 4.125 stroke for 423" small Block.
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704054
11/27/14 07:50 PM
11/27/14 07:50 PM
Northern Indiana
Northern Indiana
I took the previously ported RPM heads out as far as possible for some more port volume and flow.
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704055
11/27/14 07:55 PM
11/27/14 07:55 PM
Northern Indiana
Northern Indiana
Along with the Super Victor intake manifold
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704056
11/27/14 08:01 PM
11/27/14 08:01 PM
Northern Indiana
Northern Indiana
Final compression came out to 11.58 to 1. I am using a custom solid flat tappet camshaft.
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704057
11/27/14 08:06 PM
11/27/14 08:06 PM
Northern Indiana
Northern Indiana
First pull after seating the rings, I used my old 1 3/4" headers and modified 950 carburetor.
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704058
11/27/14 08:11 PM
11/27/14 08:11 PM
Northern Indiana
Northern Indiana
On the first pull my old reliable MP distributor started to come apart. So the power fell off fast due to timing retarding. After changing the distributor out and a little tuning we had,.....
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704059
11/27/14 08:22 PM
11/27/14 08:22 PM
Northern Indiana
Northern Indiana
After switching to 1 7/8" headers and a stockish1050 Dominator New bests.
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704060
11/27/14 08:27 PM
11/27/14 08:27 PM
Northern Indiana
Northern Indiana
Started dialing in the fuel curve but some of my jets I needed were missing so I stopped at this,point .
A little tuning should get the top end a little better than the best pull so far
I'm thinking it's not too bad for a pump premium small block with Edelbrock heads and a flat tappet cam
Keith
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704061
11/27/14 10:05 PM
11/27/14 10:05 PM
Those are oustanding results for the parts used, especially on pump gas
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704062
11/27/14 10:15 PM
11/27/14 10:15 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Wow!
Re: Small Block pump gas bracket engine [Re: RV2] #1704063
11/27/14 10:41 PM
11/27/14 10:41 PM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
Awesome what are the cam specs. Did you girdle the bottom end?
Re: Small Block pump gas bracket engine [Re: 71Pan] #1704064
11/27/14 11:39 PM
11/27/14 11:39 PM
gregsdart Offline
gregsdart  Offline
Lets see, light weight motor (sb vs bb) fast, and cheap! Pretty hard to beat that combo Most only get two out of the three!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704065
11/28/14 12:21 AM
11/28/14 12:21 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Neat build Keith! Thanks for sharing
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704066
11/28/14 12:32 AM
11/28/14 12:32 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Nice Kieth Now you have the long wait till spring.
Re: Small Block pump gas bracket engine [Re: DblOJoe] #1704067
11/28/14 01:20 AM
11/28/14 01:20 AM
Northern Indiana
Northern Indiana
Thanks for the kind words everyone! The cam is a custom grind I did. It is 270/ 276 @ .050. The lift is just under .650 after lash.
Keith
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704068
11/28/14 02:04 AM
11/28/14 02:04 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Nice build! What rocker arms are you running (and ratio, etc.)?
Re: Small Block pump gas bracket engine [Re: DblOJoe] #1704069
11/28/14 02:24 AM
11/28/14 02:24 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Great numbers
That should easily get a 3200-3300 pound car in the 9's with no sweat.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Small Block pump gas bracket engine [Re: Dunnuck Racing] #1704070
11/28/14 02:38 AM
11/28/14 02:38 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
nice combo and great numbers. my 408 cant seem to get there with similar compression and better flowing indy heads. those edelbrocks are working very well.
Re: Small Block pump gas bracket engine [Re: Cab_Burge] #1704071
11/28/14 02:56 AM
11/28/14 02:56 AM
Az
Crizila Offline
Crizila  Offline
Az
Exactly what octane pump gas are you using and what total lead are you running - and what AF ratio are you shooting for?
Fastest 300
Re: Small Block pump gas bracket engine [Re: Crizila] #1704072
11/28/14 10:52 PM
11/28/14 10:52 PM
Northern Indiana
Northern Indiana
I am running the local 93 octane premium which states 10% ethanol. When I test it, it shows 6% ethanol content.
Previous testing with this fuel has shown it normally makes best power around 12.2 to 1 a/f ratio. This thing is showing 12.8 to 1 on the O2 meter right now on the top of the pull.
Plug readings and testing so far confirmed that it needs more fuel.
Best power so far has been with 33 degrees total timing.
I also have available around here some non ethanol 93 that usually makes more power and likes a slightly leaner mixture.
Keith
Page 1 of 3 1 2 3
