Re: FORD 8.8 REAR................
[Re: Mopar-Al]
#1702684
12/04/14 02:19 AM
12/04/14 02:19 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I plan on pulling the dana out of my dart next year and doing a well built 9. Chris up in Battle Ground is going to do the work.
I now have learned more than I ever wanted to know about the Ford 8.8 rear end and have not changed my opinion one bit about my choice of rear axles for my 3,800#+ truck. It is getting the Dana 60 that I built from a thick wall truck axle with a spool, stock 4.10 gears, Ford "Torino" wheel bearings and Ford racing drum brakes. The truck will never run over 120mph in the quarter and I don't need to spend huge money on a rear end. This a dedicated race vehicle, but my goals are modest as is my budget. I want to have fun and not be a slave to the race car.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 1967dartgt]
#1702685
12/04/14 07:30 AM
12/04/14 07:30 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Two different worlds, drag racing and 4x4 trucks. Dead hooking a 1500hp car is a lot harder on parts then a 4x4 spining off road where traction is a minumin. If you think a dana 70 is only 15-30 more pounds then a chromoly housing, aluminum center section 9 inch your crazy.
Tell that to the jeep guys that have serious traction in the rocks, they slide a little back, wheel is under load and then catches...Many v8 powered jeeps have either broke something like a shaft or a housing or launched the vehicle over backwards. It aint muddin I am talkin about here... oh and the 70 with 40 spline axles are good up to 8000 ftlbs of momentary torque, the 60 is good for 6000 lbft of momentary torque with 35 spline. I don't see any 9 with factory parts rated to even close to those numbers the 8.8 with 31 splines is about 5100, the 9 is 5500 per one chart on the web. So you can decide what you want....just barely makin it or never going to break. I went with a 70, it was like 6 lbs heavier than an HD 60, I don't think I will ever break it under normal circumstances. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1702687
12/04/14 03:32 PM
12/04/14 03:32 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Last time I checked a prepped smooth racing surface has way more grip then any rocks I found off road. Haven't seen any 1500 hp rock crawlers either. If you want a Dana 70 and all that weight in the car that's fine, as for me I want to go fast.
You do know Montes 9 inch is behind 700+ cubic inch nitrous breathing monster and lives fine, but I guess that's not the same as some rock buggy with a ls 6.0 liter in it. Do me a favor and put your car, when your done building it, on a scale and tell me what it weights. Also why do we need to put factory parts in these rears the aftermarket is full of awesome super strong parts for a 9 inch. I am building a race car not a confined to factory parts.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: HEMI472]
#1702689
12/04/14 05:11 PM
12/04/14 05:11 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
There is so much in this thread I don't know if I should even bother. A friends 85 Mustang that he raced in a Street STOCK class running only 12.3's when it broke it's first 8.8, with traction lock, when it twisted the end off a stock axle, the rebuild upped it to a spool, c clip eliminators and 31 spline axles with more gear , this was behind a 5 speed running slicks and launching at 4000 rpm. Fast forward to 2013 , different mustang , now a V6 5 speed, running low 13's , Ford Motorsport 8.8 with 3.73's, the trac lock lasted one short season , now it's got a tru trac in it, still with slicks and still launching at 4000 rpm , axles should be next ??? He has his original rear as backup , it's his daily driver ... Dom , you can do all the bracing , axle bearing change , heavy duty caps you want to the 8 3/4 , pick whatever size pinion you want because in the end they are ALL THE SAME SIZE where the outer pinion bearing slides on ... you still won't fix the weak link ... RING AND PINION teeth breaking off .
[Re: astjp2]
#1702694
12/04/14 09:05 PM
12/04/14 09:05 PM
1967dartgt
Hilltown Pa
Purple shafts, 906s, pinion snubbers and Dana 60s for every body. It's what all the fast guys use!!
[Re: JohnRR]
#1702695
12/04/14 10:56 PM
12/04/14 10:56 PM
KOS
ive broken many 8 3/4s and many 8.8s also in my years of racing im on my 4th dana 60 and have never broke anything its kinda like you forget its even there its not a concern.my buddys 67 Superstock camaro had a stock 70runner dana 60 under for over 25yrs of racing with a t-brake also it wasnt until he put a 500"victor headed BB in it running low 9s then he finally broke the stock posi in it and twisted the axles.dont see to many bone stock rears doin that
[Re: Challenger 1]
#1702699
12/05/14 05:32 PM
12/05/14 05:32 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
Sure I knew it was joke, the 2 speed rear.
I should have put some jokers in my post. I think it was my last post before bed last night and my mind might have been slightly clouded.
I put a Eaton two speed under drive rear end in my old Class A motorhome, 1.5 ton I.H. chassis years ago, it really helped it a bunch 6.30 or so in under drive and 4.57 in direct, it had a 4.89 ratio in the stock rear end originally. I would leave it in under drive in town and shift it manually out on the road with a electric switch. It worked great for hills and backing the boat trailer into the water slowly Boy, some of the stuff we hot rodder do to get better performance from our vechiles Now back to are original discussion on them no good Ford rear ends of all sizes
[Re: Cab_Burge]
#1702700
12/05/14 07:41 PM
12/05/14 07:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I had a BIG old 2 speed diff in my old Dodge dump truck and it needed it... I put a 360 in the truck(had a /6).. what a gutless wonder
[Re: MR_P_BODY]
#1702701
12/05/14 10:39 PM
12/05/14 10:39 PM
Challenger 1
Cincinnati, Ohio
Yup this is our only truck left with a 2 speed rear, it's a 1990 truck antique/backup truck now. This is at least the second and probably the 3rd time I had it out getting rebuilt. This truck has a DT 466 diesel and a 5 speed trans. Learned to drive big trucks in this configuration back in 1978 at my third job. Then you had chueffer SP? license. I was grand fathered into a CDL, only took the paper test and still do every 4 years to maintain my hazmat endorsement.
[Re: Challenger 1]
#1702702
12/06/14 12:32 AM
12/06/14 12:32 AM
MR_P_BODY
I was driving a wrecker back in 69 .. that was my first with the 2 speed diff.. it was a diesel and a 5 speed.. I had to have the chauffeur license also
