Re: FORD 8.8 REAR................
[Re: JERICOGTX]
#1702545
11/24/14 10:45 PM
11/24/14 10:45 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I know of lots of low 5s cars running 8.8s. Stock ring gear bolts suck.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Thumperdart]
#1702547
11/25/14 02:37 AM
11/25/14 02:37 AM
Posts: 793 Utah
topbrent
Utah
Why not a Dana 60 dom?
They look too "obvious" in an a body to me..............just my personal thing. To me a braced bad ass 8 3/4 or 9" just looks plain mean and clean and less like a truck.
...Yup, you certainly don't wanna give away any of that fresh out of granny's garage, sleeper vibe you have going on by installing a dana. Sheesh, that would be a complete and total give-away right there. I mean, a dana would definitely be more obvious than the big scoop on the hood, the purple paint, the huge roller cam and the loud exhaust, ect, right?
Just having fun with you Dom! Everyone has their own tastes and definitions I suppose.
[Re: WHITEDART]
#1702551
11/25/14 02:19 PM
11/25/14 02:19 PM
Quicktree
I don't think it's a matter of who goes fast on an 8.8. it's a matter of if he's going to upgrade is that the best choice. I don't think it is, he would be better off doing it right the first time.
[Re: Quicktree]
#1702553
11/25/14 03:08 PM
11/25/14 03:08 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Most "fast" cars that have 8.8, 12 bolts, 8.75, etc, rears have them, because at one time the car was not near that fast and the rear under it was "good enough" at that time. As time wears on, a complete replacement is usually a pretty good cost, so the OK rear gets patched and band aided to try and make it passable. Nobody in their right mind is going to start a NEW build and say "I think I will put an 8.8 rear in my new low 5 sec radial car"..........c'mon.
The Buick we currently race in Drag Radial, had a 10 bolt under it when we bought it. The car had run 5.50s with small blocks when we bought it and our big block made it a 5.20 car right off the bat. We ran the 10 bolt until we broke it (which wasn't long). The point was, the car "evolved" from a streeter to a low 5 sec car and the 10 bolt was "good enough" to a point.......then it wasn't.........so in Dom's case, moving from an 8.75 TO an 8.8 under his car........well he may as well light that money on fire, because it will accomplish the same thing.
Monte
[Re: Thumperdart]
#1702555
11/25/14 06:19 PM
11/25/14 06:19 PM
Posts: 6,295 U.S.
moparniac
U.S.
Dana60 with a cool diff cover.
Mopar Performance
[Re: onig]
#1702557
11/25/14 08:55 PM
11/25/14 08:55 PM
Monte_Smith
North Alabama
Monte
Just curious Monte, what rear is in that Buick?
Chromoly 9" sheetmetal Ford housing, with 40 spline gun drilled axles, alum Mark Williams center, with a 3.70 Pro gear and a billet 1350 yoke with a solid joint............expensive? yeah I guess, but high power, hard hooking radial cars will break EVERYTHING. Radial cars are harder on drive line parts by FAR than slick tire cars. That said, we have NEVER broken a single part in the rear...........Several radial guys I know this year were twisting and breaking 40 spline axles. That's how hard these cars can be on parts.
Monte
[Re: Monte_Smith]
#1702558
11/25/14 10:41 PM
11/25/14 10:41 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Monte
Monte
If thats the case, then move up to a Dana 70, 10.5" ring gear, 35 spline axles, 3.5 tubes with .5 wall thickness, looks like a 60 but on steroids inside! 1401 ujoints and a bunch of ratio's up to 7.17 to 1 Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1702559
11/25/14 11:00 PM
11/25/14 11:00 PM
Monte_Smith
North Alabama
Monte
Monte
You're kidding right.........why would I put that heavy pos in the car when it has a real "race car" rear in it now.
I said OTHER guys had twisted another brand of 40 spline axles, but we are having no issues. And if other guys are twisting 40s, you think a DANA with 35s is gonna be better.......okie dokie, but I will pass.
Monte
[Re: astjp2]
#1702560
11/26/14 11:54 AM
11/26/14 11:54 AM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
Monte
Monte
Oh I love getting on here. Twisting 40 spline axles and should go back to 35 spline and add 150 lbs in the process. That is exactly what they should do. I think you should call all the big chassis shops and get them all on board with the dana 70 movement also. You better buy up all the parts they are going to be flying off the shelf.
One day I will have something cool here.
[Re: sdaurity]
#1702561
11/26/14 01:24 PM
11/26/14 01:24 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
,looking to buy a new rear-end in the next week or 2, my factory 8 3/4 may not be up to the 535 stroker 6 pak,cope built 727 tranny, and the slicks, this is in my 70 runner,with the stroker expected to make 650 hp and 6?? torque, want to add a rear that will not fail me, as this is all new and i will being put together next month, thoughts were to buy a DANA (to stick with mopar)car will not be tubbed but inner wheel wells massaged for bigger meats. So in short a good read post
[Re: meepmeep70]
#1702562
11/26/14 04:47 PM
11/26/14 04:47 PM
Quicktree
just a tip, Dana is not mopar. they came in just about all trucks. mopar used them because they knew the 83/4 wouldn't handle the big hemi's and 440s
[Re: sdaurity]
#1702563
11/26/14 04:48 PM
11/26/14 04:48 PM
Quicktree
Monte
Monte
heck I am heading to the junk yard today to see if I can find a dump truck rear to put in mine
