Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702544
11/24/14 09:48 PM
11/24/14 09:48 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
A coworker is running a 8.8 in his Drag Radial Mustang. Has a 632 BBC running 8.30's. I personally wouldn't run one at that speed, but it has held up for him.
Jeff
Seems crazy fast unless he spared no expense I guess..............
Not really. Just has a spool and 35 spline axles. Still has the factory drum brakes... As I said, I personally would not run it, but he has not had a problem in 5 years with his combo.
69 GTX 68 Road Runner
Re: FORD 8.8 REAR................ [Re: JERICOGTX] #1702545
11/24/14 10:45 PM
11/24/14 10:45 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I know of lots of low 5s cars running 8.8s. Stock ring gear bolts suck.
Re: FORD 8.8 REAR................ [Re: moparniac] #1702546
11/24/14 11:08 PM
11/24/14 11:08 PM
State of confusion
Thumperdart Offline OP
State of confusion
Why not a Dana 60 dom?
They look too "obvious" in an a body to me..............just my personal thing. To me a braced bad ass 8 3/4 or 9" just looks plain mean and clean and less like a truck.
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702547
11/25/14 02:37 AM
11/25/14 02:37 AM
Utah
topbrent Offline
topbrent  Offline
Utah
...Yup, you certainly don't wanna give away any of that fresh out of granny's garage, sleeper vibe you have going on by installing a dana. Sheesh, that would be a complete and total give-away right there. I mean, a dana would definitely be more obvious than the big scoop on the hood, the purple paint, the huge roller cam and the loud exhaust, ect, right?
Just having fun with you Dom! Everyone has their own tastes and definitions I suppose.
Re: FORD 8.8 REAR................ [Re: sixpackgut] #1702548
11/25/14 02:44 AM
11/25/14 02:44 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702549
11/25/14 02:46 AM
11/25/14 02:46 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
i will make you a dill on my 9in read to go
Re: FORD 8.8 REAR................ [Re: WHITEDART] #1702550
11/25/14 03:03 AM
11/25/14 03:03 AM
State of confusion
State of confusion
PM Me the length end to end and the price if you don`t mind.
Re: FORD 8.8 REAR................ [Re: WHITEDART] #1702551
11/25/14 02:19 PM
11/25/14 02:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I don't think it's a matter of who goes fast on an 8.8. it's a matter of if he's going to upgrade is that the best choice. I don't think it is, he would be better off doing it right the first time.
Re: FORD 8.8 REAR................ [Re: Quicktree] #1702552
11/25/14 03:06 PM
11/25/14 03:06 PM
State of confusion
State of confusion
Looks like I`ll be gettin WHITEDART`s 9" after the M.A.T.S. unless it blows up or I find something sooner........ Time to step up................
Re: FORD 8.8 REAR................ [Re: Quicktree] #1702553
11/25/14 03:08 PM
11/25/14 03:08 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Most "fast" cars that have 8.8, 12 bolts, 8.75, etc, rears have them, because at one time the car was not near that fast and the rear under it was "good enough" at that time. As time wears on, a complete replacement is usually a pretty good cost, so the OK rear gets patched and band aided to try and make it passable. Nobody in their right mind is going to start a NEW build and say "I think I will put an 8.8 rear in my new low 5 sec radial car"..........c'mon.
The Buick we currently race in Drag Radial, had a 10 bolt under it when we bought it. The car had run 5.50s with small blocks when we bought it and our big block made it a 5.20 car right off the bat. We ran the 10 bolt until we broke it (which wasn't long). The point was, the car "evolved" from a streeter to a low 5 sec car and the 10 bolt was "good enough" to a point.......then it wasn't.........so in Dom's case, moving from an 8.75 TO an 8.8 under his car........well he may as well light that money on fire, because it will accomplish the same thing.
Monte
Re: FORD 8.8 REAR................ [Re: Monte_Smith] #1702554
11/25/14 03:11 PM
11/25/14 03:11 PM
State of confusion
State of confusion
Exactamundo Monte..............read above post...........
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702555
11/25/14 06:19 PM
11/25/14 06:19 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Dana60 with a cool diff cover.
Mopar Performance
Re: FORD 8.8 REAR................ [Re: Monte_Smith] #1702556
11/25/14 06:52 PM
11/25/14 06:52 PM
Canada
onig Offline
onig  Offline
Canada
Monte
Just curious Monte, what rear is in that Buick?
69 Dart
Re: FORD 8.8 REAR................ [Re: onig] #1702557
11/25/14 08:55 PM
11/25/14 08:55 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
Chromoly 9" sheetmetal Ford housing, with 40 spline gun drilled axles, alum Mark Williams center, with a 3.70 Pro gear and a billet 1350 yoke with a solid joint............expensive? yeah I guess, but high power, hard hooking radial cars will break EVERYTHING. Radial cars are harder on drive line parts by FAR than slick tire cars. That said, we have NEVER broken a single part in the rear...........Several radial guys I know this year were twisting and breaking 40 spline axles. That's how hard these cars can be on parts.
Monte
Re: FORD 8.8 REAR................ [Re: Monte_Smith] #1702558
11/25/14 10:41 PM
11/25/14 10:41 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Monte
Monte
If thats the case, then move up to a Dana 70, 10.5" ring gear, 35 spline axles, 3.5 tubes with .5 wall thickness, looks like a 60 but on steroids inside! 1401 ujoints and a bunch of ratio's up to 7.17 to 1 Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: FORD 8.8 REAR................ [Re: astjp2] #1702559
11/25/14 11:00 PM
11/25/14 11:00 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
Monte
You're kidding right.........why would I put that heavy pos in the car when it has a real "race car" rear in it now.
I said OTHER guys had twisted another brand of 40 spline axles, but we are having no issues. And if other guys are twisting 40s, you think a DANA with 35s is gonna be better.......okie dokie, but I will pass.
Monte
Re: FORD 8.8 REAR................ [Re: astjp2] #1702560
11/26/14 11:54 AM
11/26/14 11:54 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Monte
Monte
Oh I love getting on here. Twisting 40 spline axles and should go back to 35 spline and add 150 lbs in the process. That is exactly what they should do. I think you should call all the big chassis shops and get them all on board with the dana 70 movement also. You better buy up all the parts they are going to be flying off the shelf.
One day I will have something cool here.
Re: FORD 8.8 REAR................ [Re: sdaurity] #1702561
11/26/14 01:24 PM
11/26/14 01:24 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
,looking to buy a new rear-end in the next week or 2, my factory 8 3/4 may not be up to the 535 stroker 6 pak,cope built 727 tranny, and the slicks, this is in my 70 runner,with the stroker expected to make 650 hp and 6?? torque, want to add a rear that will not fail me, as this is all new and i will being put together next month, thoughts were to buy a DANA (to stick with mopar)car will not be tubbed but inner wheel wells massaged for bigger meats. So in short a good read post
Re: FORD 8.8 REAR................ [Re: meepmeep70] #1702562
11/26/14 04:47 PM
11/26/14 04:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
just a tip, Dana is not mopar. they came in just about all trucks. mopar used them because they knew the 83/4 wouldn't handle the big hemi's and 440s
Re: FORD 8.8 REAR................ [Re: sdaurity] #1702563
11/26/14 04:48 PM
11/26/14 04:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte
Monte
heck I am heading to the junk yard today to see if I can find a dump truck rear to put in mine
