Page 2 of 3 1 2 3
Re: Any stock or stock eliminator racers here????? [Re: GTX MATT] #1702454
11/24/14 04:14 PM
11/24/14 04:14 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
What are you allowed to modify/change?
Basically, it's a "stock" motor and car...stock bore and stroke (within a certain spec)...stock, unmodified heads....stock pistons (or equivalent replacement)...stock, unmodified intake...stock carb...stock lift camshaft, any duration...headers, any converter, any gear and 30X9 max tire...
But, there's a LOT of "creative interpretation of the rules" going on...
If you can't handle the truth, you're living a lie.......
Re: Any stock or stock eliminator racers here????? [Re: Big Squeeze] #1702455
11/24/14 04:36 PM
11/24/14 04:36 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Basically, it's a "stock" motor unmodified heads....
Need to be changed to stock appearing heads
[img] [/img]
Re: Any stock or stock eliminator racers here????? [Re: clonestocker] #1702456
11/24/14 05:42 PM
11/24/14 05:42 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
30 x 9 max tire size. And if you run Stock pistons, parts etc it will likely be an index car. There is a list of NHRA approved replacement parts... pistons, heads- casting #'s etc.... There is alot of technology (=$$$$$$) that goes into these "stock" engines. Everything is massaged and blueprinted. There is a tolerance for all specs and they need to be checked and lots of machine work needed to be competitive.
Get a rulebook and get reday to get into the minutiae of every part on the car. Alot of work but Very Very rewarding. My uncle ran stock and super stock until he died, now my cousin has taken over and I help out when I can.
Re: Any stock or stock eliminator racers here????? [Re: BIG DRAG] #1702457
11/25/14 02:05 AM
11/25/14 02:05 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Any of the Stocker guys know what the limitations of "any valve job" means? On Classracer they seem to interpret that to mean "radially symmetric" (my words) in that the cuts are the same distance from the valve centerline all the way around. They don't exactly say how far down you can go? I'm thinking all the way down to the guide or maybe a little further if the flow picks up?
I was disappointed the video didn't show anything on the 1964 Plymouth in the barn. Was that Hagburg's car? I would have liked to see the V10 head on the DP Challenger. I'd like to see what a 268cc intake port looks like.
Re: Any stock or stock eliminator racers here????? [Re: mr_340] #1702458
11/25/14 10:51 AM
11/25/14 10:51 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Don't be silly... the valve job can go all the way up into the intake
Re: Any stock or stock eliminator racers here????? [Re: scatpacktom] #1702459
11/25/14 12:01 PM
11/25/14 12:01 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
There was the .250 rule in effect for decades. Then a few years ago it disappeared. Now your can throat to a certain extent. Some heads benefit more than others from this.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Any stock or stock eliminator racers here????? [Re: maxie] #1702460
11/25/14 12:13 PM
11/25/14 12:13 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
What's the difference in stock and stock eliminator?
Cars require full stock interior?
What is the best mopar non hemi powered for the classes?
Curious as to why you're asking? Are you thinking of building/buying one??
Re: Any stock or stock eliminator racers here????? [Re: Big Squeeze] #1702461
11/25/14 12:38 PM
11/25/14 12:38 PM
NC
barracuda man Offline
NC
I think i would buy one already built.They are big$$$$.I had a 67 barracuda full interior that went 8.50ets in the 1/8 mile.Not sure what the stock class would be.Oh it had the hp273 i still got in the corner of shop.I don't think the 67 barrrcuda's came with the 340's till 1968.
Re: Any stock or stock eliminator racers here????? [Re: barracuda man] #1702462
11/25/14 12:56 PM
11/25/14 12:56 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Stock Class Racing requires one thing to be competitive deep pockets
But NHRA has changed some stuff for 2015, the newer cars 2008 and up will have their own classes and that lets some of the older combos be a viable car again.
Just check out class racerracer.com
Switched to the dark side...
Re: Any stock or stock eliminator racers here????? [Re: maxie] #1702463
11/25/14 01:51 PM
11/25/14 01:51 PM
Indianapolis Indiana
Jamie340 Offline
Jamie340  Offline
I race stock eliminator, mostly NHRA events. However, I have as much if not more fun racing bracket.
I will try to answer any questions.
Jamie 1971 Demon340 D/SA 10.57 @ 122.00 mph 1.37
60' Mine shaft air, with a tailwind.
Re: Any stock or stock eliminator racers here????? [Re: Jamie340] #1702464
11/25/14 05:10 PM
11/25/14 05:10 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
I will be running super stock for 2015 in div.1 this is my first year. I ran NSS Hemi class with my Cuda. I have a thread on here from when I built it. I was going to go to a stocker wedge, well that was the plan anyway. I hurt the Hemi so the plan changed faster. I ended up going to super stock because a very good allready proven package came available. The r & d will kill it if you are one a budget to be competitive.if you plan on running a Chrysler be prepared to spend more than you want to if you want to be in the higher end of the food chain. I have not posted on here about this yet but decided to put my 2 cents in here. Biggest thing I think for anyone is havering a good support team of people who are into it. You will need all the help you can get, technology has changed so much on stock & SUPERSTOCK it will blow people's minds how far they have to take these motors to be competitive. Also you need to ask yourself if you want to just class race or do it with style in a car you like. There is a difference.
Re: Any stock or stock eliminator racers here????? [Re: Jamie340] #1702465
11/25/14 07:17 PM
11/25/14 07:17 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I too seem to have more fun at the Mopar events or Mike Carr S/SS races. The 400 plus entry for National Events takes some of the fun out of it.
1959 Bugeye Sprite
1971 MG Midget
Re: Any stock or stock eliminator racers here????? [Re: sixpackbee] #1702466
11/25/14 07:29 PM
11/25/14 07:29 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
I would love to run a Super Stock car, just don't have the coin to turn my 69 Dart into one.
Re: Any stock or stock eliminator racers here????? [Re: classracer] #1702467
11/25/14 07:54 PM
11/25/14 07:54 PM
Guitar Jones Offline
There are a few stock eliminator racers on Moparts. Most like myself are just lurking around. To answer some....It can be expensive, it just depends on what you want to do and how much you want to spend.
Re: Any stock or stock eliminator racers here????? [Re: Guitar Jones] #1702468
11/25/14 09:26 PM
11/25/14 09:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can tell you my brother drove Danny Jones B/SA 64 Max Wedge Plymouth for a few seasons and now he just races in NSS with the 422 club. And he told me he enjoys running NSS with the 422 club much more then running in NHRA Stock eliminator class. Ron
Re: Any stock or stock eliminator racers here????? [Re: mr_340] #1702469
11/26/14 01:00 AM
11/26/14 01:00 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Not sure whose, but they have someone's CNC port program in them, I could see that through the oil film in every intake port.
Re: Any stock or stock eliminator racers here????? [Re: Big Squeeze] #1702470
11/26/14 05:24 PM
11/26/14 05:24 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, also, ring combo's are critical, wall finish, , valve seat angles, type of valves, crank indexing stroke equalized, port flows and velocity. all ports flow same. intake manifold casting, carb rework for flat fuel curve, suspension.
Re: Any stock or stock eliminator racers here????? [Re: perfmachst] #1702471
11/27/14 12:33 AM
11/27/14 12:33 AM
Winter Park, Florida
classracer Offline
classracer  Offline
If you don't have a bunch of this:
" also, ring combo's are critical, wall finish, , valve seat angles, type of valves, crank indexing stroke equalized, port flows and velocity. all ports flow same. intake manifold casting, carb rework for flat fuel curve, suspension." etc., etc., etc., etc.
The best set of "STOCK APPEARING" heads will not help.
Re: Any stock or stock eliminator racers here????? [Re: classracer] #1702472
11/27/14 12:44 AM
11/27/14 12:44 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Don't forget the 20 converters that are pumped through the car or the several different gear ratio sets in the 904. The suspensions in both my a bodies are pretty simple. Engine wise it is ring package and camshaft/valvetrain. Need to make these things rpm.
1959 Bugeye Sprite
1971 MG Midget
Re: Any stock or stock eliminator racers here????? [Re: moparpollack] #1702473
11/27/14 12:46 AM
11/27/14 12:46 AM
Locomotion Online content
Locomotion  Online Content
They don't say if it has to sustain weight of a passenger do they?
Passenger seat has to match the driver's seat.
I suppose you can swiss-cheese it under the upholstery, but I'd hate to do that if I already had lightweight seats in it.
Page 2 of 3 1 2 3
