ULTRASONIC CLEANERS............... #1702223
11/23/14 03:13 PM
11/23/14 03:13 PM
State of confusion
Thumperdart Offline OP
State of confusion
I`ve been using one to clean my carbs and man what a difference it makes. Anyone else mess w/these things?
Re: ULTRASONIC CLEANERS............... [Re: Thumperdart] #1702224
11/23/14 03:34 PM
11/23/14 03:34 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive used them in my business for the last 40 years.
Re: ULTRASONIC CLEANERS............... [Re: bonefish] #1702225
11/23/14 03:36 PM
11/23/14 03:36 PM
State of confusion
State of confusion
I put a "clean" carb part in and after that NO carb will ever be built any other way from here on out.
Re: ULTRASONIC CLEANERS............... [Re: Thumperdart] #1702226
11/23/14 03:36 PM
11/23/14 03:36 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
What is the typical application of one? Sounds like a great idea for all of the anodized aluminum stuff.
Re: ULTRASONIC CLEANERS............... [Re: Jeremiah] #1702227
11/23/14 03:37 PM
11/23/14 03:37 PM
State of confusion
State of confusion
Generally gun parts, cases etc, jewelery and other small items and even has a heat cycle...........
Re: ULTRASONIC CLEANERS............... [Re: Jeremiah] #1702228
11/23/14 03:45 PM
11/23/14 03:45 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
they are typically used in the medical field on reusable surgical tools before autoclave.it gets all the STUFF out of crevaces.nowadays just about everything is disposable.i used them in tattooing,but there again now everything is disposable.
Re: ULTRASONIC CLEANERS............... [Re: Jeremiah] #1702229
11/23/14 04:23 PM
11/23/14 04:23 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Most of us "gun guys" use them for cleaning cases before reloading ammo. They make them in various sizes. Check your local Cabellas, Bass Pro, Dick's, Gander Mountain, etc
Monte
Re: ULTRASONIC CLEANERS............... [Re: Monte_Smith] #1702230
11/23/14 05:35 PM
11/23/14 05:35 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
I bought the el-cheapo Harbor freight one to rebuild the 3 carbs on my Six Pack Demon. Read about ultrasonic cleaners online and figured $60 was cheap enough to try. Used very hot water with some Simple Green Pro. Doesn't harm the aluminum like regular Simple Green will. 8 min cycles cleaned every part like brand new. I will probably look at buying a bigger unit because you can't get a 4 barrel into this one. For sure, there is no better way to clean them!
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: ULTRASONIC CLEANERS............... [Re: Monte_Smith] #1702231
11/23/14 05:44 PM
11/23/14 05:44 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Use solvents that don't extracts zink.
Many high pH (11-13) solvents will attack alum. Zink and brass. Most Alkali solvents should not be used with alum.
I am not a chemist, but work with big cabin washer for pre-treatment in painting process.
Re: ULTRASONIC CLEANERS............... [Re: RT540] #1702232
11/24/14 12:37 PM
11/24/14 12:37 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I have a small one for rods etc. but I want one big enough for a block.
2011 Drag Pak Challenger
Re: ULTRASONIC CLEANERS............... [Re: RT540] #1702233
11/27/14 04:36 AM
11/27/14 04:36 AM
Chicago
PurpleBeeper Offline
Chicago
Also, don't use low pH cleaners either (1-4) because they will dissolve the metals. Something near neutral would be safest (5-9) like dish soap and maybe some rubbing alcohol? p.s. I am a chemist
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: ULTRASONIC CLEANERS............... [Re: Thumperdart] #1702234
11/27/14 04:47 AM
11/27/14 04:47 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Thanks for the tips guys, I am in the market for one and I hadn't really thought about what cleaning solution to use for different jobs.
"Just a Bracket car dressed up like a streetcar"
Re: ULTRASONIC CLEANERS............... [Re: Monte_Smith] #1702235
11/27/14 04:53 AM
11/27/14 04:53 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Monte
Are you saying my walnut shell filled tumbler is obsolete?
Is there a non-harbor freight brand that we like more than others?
Re: ULTRASONIC CLEANERS............... [Re: Jeremiah] #1702236
11/27/14 12:29 PM
11/27/14 12:29 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I am a big fan of ultrasonic cleaners. When I worked at a COOP job in the eighties, we made small ones for the dental industry. They gave me one that I still use today. Its not super strong but it works pretty good.
We used ammonia with hot water for the solution. I don't know the pros and cons of using ammonia.
The way we would test the strength of an ultrasonic cleaner is to use aluminum foil and time for how long it would take to make holes in the foil. Does not take long - the learning there is that the ultrasonic cleaner will attack aluminum. I just don't leave parts like carbs in it too long. Have had great success bringing small snowblower carbs back to life with the ultrasonic cleaner.
In the industrial world we have a large problem with carbon being trapped in the commutator and behind the riser on large DC motors. Almost impossible to get the carbon out, and usually you just dilute it and make it worse when you clean it.
For many years I have been advocating use of an ultrasonic cleaner to get the carbon out. Started some trials about 5 years ago and results were quite promising. Could not get the repair shops to bite on the idea though until very recently. Last few weeks 2 motor repair shops ordered large ultrasonic cleaners.
Re: ULTRASONIC CLEANERS............... [Re: markz528] #1702237
11/27/14 02:57 PM
11/27/14 02:57 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
http://www.homedepot.com/p/Simple-Green-...13421/100550784
After looking online at what others were using, this is what I used for my trial run on the 6 pack carbs and worked very well. It is not corrosive to metal.
Matt
69 Dart Swinger 340
and even more
Re: ULTRASONIC CLEANERS............... [Re: herkamer] #1702238
11/27/14 03:08 PM
11/27/14 03:08 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
we have a large ultra sonic cleaner at work that i would use. I really was amazing how well it worked.
Re: ULTRASONIC CLEANERS............... [Re: PurpleBeeper] #1702239
11/27/14 03:40 PM
11/27/14 03:40 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Yes both high and low pH are both aggressiv for alum.
We only build the cabin washers and the end customer decides which chem. Company to buy from.
We do work close with the chemist to make the best end result.
Three big companys we work close with are Chemetall, Henkel and Candor.
Re: ULTRASONIC CLEANERS............... [Re: herkamer] #1702240
11/27/14 03:43 PM
11/27/14 03:43 PM
State of confusion
State of confusion
Think I`ll give that a try since others have reported great results from it...............
Re: ULTRASONIC CLEANERS............... [Re: herkamer] #1702241
11/27/14 03:53 PM
11/27/14 03:53 PM
I owned a airplane until 2006 when it was total by a hail storm while parked on the ground. I was told by multiple A&P FAA certified mechanics to not use Simple Green on any alumimun parts on the airplane Maybe this stuff isn't that destructive to aluminum due to a change in the formula, it is not green like the original was back then Be safe
Re: ULTRASONIC CLEANERS............... [Re: Cab_Burge] #1702242
11/27/14 03:58 PM
11/27/14 03:58 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Cab there is regular green Simple Green and then there is the blue "HD Pro" stuff that is okay to use on metal.
