Re: 68 Charger Axle Play
[Re: markz528]
#1701698
11/28/14 02:11 AM
11/28/14 02:11 AM
Posts: 32 Santa Barbara, California
Edahlke
Here are summit's directions that I'm working with, they're not great but you can see all the parts involved in the one exploded view The total width added to each side is .38". The skinnier plate you see in the directions which they say to use with one piece axles only measures .13", while the outer most plate (which the directions refer to as the split mounting bracket) is .25". Instructions
[Re: Edahlke]
#1701703
12/03/14 07:54 PM
12/03/14 07:54 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
... I pulled the axle out and shined a flashlight down the tube and saw what appeared to be a thrust button. I tried fishing it out, but it just dropped down inside the differential housing.
Just a bit of useful "100 miles from nowhere" info:
Early thrust buttons used a roll pin between the buttons, this was the design that was prone to having the button(s) fall in when an axle was removed. Later versions used what is almost a "nail", you peened over the headless end when installing.
The point is that both systems were just an assembly aid. You can stick the buttons in with heavy grease, daub of RTV, whatever, pop the pig and axles in, you'll be fine...until next time you pull the axles, of course.
Natch, be sure the pin isn't floating in there somewhere.
Rick
