Re: Where to purchase fasteners for your Mopar Resto?
[Re: DRJDVM]
#1701285
11/24/14 04:32 AM
11/24/14 04:32 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Understood. Post your questions, and I'll bet the forum will help.
I'll be pulling my crank bolt soon, and then I'll know the full details. It's a 340 but may be the same as BB.
[Re: vinnyd76]
#1701287
11/25/14 04:45 AM
11/25/14 04:45 AM
kentj340
Cut and Shoot, TX
What AMK offers is on page 198 here: http://www.amkproducts.com/Catalog_PDF/196-201.pdfSays C-8204 crankshaft damper for 383/440 and C-8059 crankshaft damper for SB & 426 Hemi, includes 1 hex bolt and 1 flat washer, 1964-1974, $8 each, with no description of size nor head markings. So now we know 383 and 440 are the same and SB and 426 are the same, and, as posted, the C-8204 has a triangle on the head and not an LE. As mentioned above, the bolt might have the correct head marking only for certain models, years, or plants and not others. If you just want the right size, thread, and material spec, these bolts should work. Minimum order is $30.
