Page 2 of 3 1 2 3
Re: Master Cylinder Color [Re: Kern Dog] #1701070
11/20/14 05:40 PM
11/20/14 05:40 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
That totally depends on the car, the brake package and the year.
Best answer so far!!!!
Ron
Re: Master Cylinder Color [Re: dart4forte] #1701071
11/20/14 05:59 PM
11/20/14 05:59 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
1968 Charger
Re: Master Cylinder Color [Re: 469runner] #1701072
11/20/14 06:27 PM
11/20/14 06:27 PM
New York
rarefish Offline
rarefish  Offline
New York
Here is a pic from a 69 Dart GTS with KH power disc brakes. I believe that it is original.
Re: Master Cylinder Color [Re: rarefish] #1701073
11/20/14 06:40 PM
11/20/14 06:40 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
There's a situation where I could believe the master to be natural but you clearly have a nice correctly stamped Black lid and bail. Are there any remnants of Black paint on the MC body?
Ron
Re: Master Cylinder Color [Re: RJS] #1701074
11/20/14 06:51 PM
11/20/14 06:51 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Pictures can be deceiving but it looks like remnants of black paint on the master to me.
Re: Master Cylinder Color [Re: Alaskan_TA] #1701075
11/20/14 07:01 PM
11/20/14 07:01 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
MS - Master Cylinder.
I meant to type MC.
....and I was just following suit so Barry wouldn't feel bad!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Master Cylinder Color [Re: burdar] #1701076
11/20/14 07:25 PM
11/20/14 07:25 PM
New York
rarefish Offline
rarefish  Offline
New York
Here is another pic of the MC. I tried to clean some of the loose rust off with a tooth bush back near the mounting nut. I can't saw for sure if it was once painted black or not. I'm leaning toward that it was.
I just bought this Dart from a friend's estate. It has only 10,000 miles on it and had been in storage since 1974. Lots of original things are still intact.
Re: Master Cylinder Color [Re: rarefish] #1701077
11/20/14 07:28 PM
11/20/14 07:28 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If you soak the master in EvapoRust, any paint that is left on it will reappear.
Re: Master Cylinder Color [Re: burdar] #1701078
11/20/14 07:36 PM
11/20/14 07:36 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
and I'm just wondering if there's an answer in my future
Re: Master Cylinder Color [Re: dart4forte] #1701079
11/21/14 02:50 AM
11/21/14 02:50 AM
NH
Bee Nice Offline
Bee Nice  Offline
NH
Charger, Road Runner, & Super Bee Authentic Restoration Guide written by Paul Herd page 95 states, Master Cylinders 1968 "The cylinder itself should be painted cast-iron gray to simulate the fresh-cast look, and the cover and hold down clamp should have cadmium gold appearance. Page 95 goes onto state The Federally-Mandated dual circuit cylinder first appeared on 1967 models. Both 67 & 68 used Part number 2808599. Chrysler Muscle Car Parts Interchange Manual written by Paul Herd page 85 shows part number 2808599 applicable to 1967-69 Barracuda, Fury, Monaco, Newport, New Yorker, and Polara. 1967 - 68 Belvedere, Charger, and Coronet, with drum brakes. Used in both power and non-power assisted applications.
Re: Master Cylinder Color [Re: Bee Nice] #1701080
11/21/14 03:04 AM
11/21/14 03:04 AM
Mesa, Arizona
Mesa, Arizona
I can live with that. Looks like that's a book I should get.
Re: Master Cylinder Color [Re: Bee Nice] #1701081
11/21/14 03:19 AM
11/21/14 03:19 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
2808599 is a drum brake master cylinder. 67-70 drum brake Mopars all used the same master cylinder and it had the bolt on style cap. Generally accepted to be cast iron with plated cap, though I have NOS examples that have the body E coated black with a plated cap.
The OP asked about a disc brake master cylinder. All the Mopar disc brake master cylinders from '67-'70 were painted gloss black except the flange and the area by the outlets where protective plugs were installed prior to painting. Here is an NOS assembly line '67-'70 A body manual disc brake master cylinder casting number 2225541 date coded 212th day of '69. Interestingly has a splotch of white paint on the front of the bore area of the casting.
Re: Master Cylinder Color [Re: Mastershake340] #1701082
11/21/14 03:26 AM
11/21/14 03:26 AM
Mesa, Arizona
Mesa, Arizona
I have the 541. So you say black is the color. Mine is date coded late 67
Re: Master Cylinder Color [Re: dart4forte] #1701083
11/21/14 03:48 AM
11/21/14 03:48 AM
Crook County, ILL
Crook County, ILL
Yours should look exactly like the assembly line example shown above. Put some protective plugs in the outlets before painting, and you are good to go.
Re: Master Cylinder Color [Re: Mastershake340] #1701084
11/21/14 04:01 AM
11/21/14 04:01 AM
Mesa, Arizona
Mesa, Arizona
Cool. Thanks
Re: Master Cylinder Color [Re: dart4forte] #1701085
11/21/14 12:40 PM
11/21/14 12:40 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
I myself would not use that book for reference restoration.
Re: Master Cylinder Color [Re: mccannix] #1701086
11/21/14 02:20 PM
11/21/14 02:20 PM
DPelletier Offline
DPelletier  Offline
There are lots of mistakes in that book.
Re: Master Cylinder Color [Re: DPelletier] #1701087
11/21/14 04:50 PM
11/21/14 04:50 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Ditto
Ron
Re: Master Cylinder Color [Re: RJS] #1701088
11/21/14 05:49 PM
11/21/14 05:49 PM
Ditto
Ron
There are lots of mistakes in every car book article I've ever seen or read
I own a 1969 Dart GTS 383 4 speed car without power brakes, it has the stock Kelsey Hayes front disc brakes on it, this is the M.C. that was on it when I bought it in the early 1990s,(this car was sold at Saddleback dodge in Orange County, CA in late 1968) it works very well, it doesn't seem to have a residual valve in the back half of the M.C., the front tires spin as easy as any other front disc brake Mopar I have owned, drivened and worked on or raced
Re: Master Cylinder Color [Re: Cab_Burge] #1701089
11/21/14 08:53 PM
11/21/14 08:53 PM
Mesa, Arizona
Mesa, Arizona
Ditto
Ron
According to themoparman (Wayne) who restores M/Cs you should have M/C 2225541 which has the 1" bore suited for the A body manual and disk brakes. Looks like you have a manual brake M/C. It also looks like someone like orange.
Page 2 of 3 1 2 3
