1990 Ramcharger speedo help #1700749
11/18/14 11:38 PM
11/18/14 11:38 PM
jacksonville,FLORIDA
slammedR/T Offline OP
Hvae a 1990 ramcharger with a speedo that isn't working. this year went to the speed sensor set-up instead of a speedo cable like earlier odels. Well can anybody recomend a shop to repair these old dodge IPC clusters?
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: 1990 Ramcharger speedo help [Re: slammedR/T] #1700750
11/20/14 02:37 AM
11/20/14 02:37 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
later model dodges run the speedo off the antilock tone wheel---the electronic sensor where the old tranny speedogear is talks to the computer about the shifting--------but i dont know the year it started in use----it could be as simple as the tone wheel sensor being bad/wiring damaged....
Re: 1990 Ramcharger speedo help [Re: savoy64] #1700751
11/20/14 01:53 PM
11/20/14 01:53 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I believe 1998 was the first year for the differential sending unit. His VSS is attached to the transmission much like the old cable units.
I'm sorry I don't know any more, neither of my units has malfunctioned yet. One just rolled past 325,000 miles.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1990 Ramcharger speedo help [Re: savoy64] #1700752
11/20/14 11:15 PM
11/20/14 11:15 PM
All ready tested the circuit it is the IPC board is the issue, the sensor is on the side of the transmission, you are thinking of newer rams after 95.
There use to be a place here that rebuilt IPCs but they have since closed and moved to miami. Never used them but was hoping some one on here has had one rebuilt before and could give me first hand experience of the shop.
Oh well guess i will hunt the old interwebz, thanks anyways peeps
racemagnum
Re: 1990 Ramcharger speedo help [Re: slammedR/T] #1700753
11/21/14 07:28 AM
11/21/14 07:28 AM
Q
Quicktree Offline
Quicktree  Offline
Q
give Chris a call at Garber dodge he is a tech in the service dept. he may know of someone. he is a racer also. good guy to get to know.
