Re: 1965 Coronet/Belvedere real weights
[Re: fullmetaljacket]
#1700560
11/23/14 04:33 AM
11/23/14 04:33 AM
Posts: 8,383 fredericksburg,va
cudaman1969
fredericksburg,va
Like i said my car was 3050 to 3100 gutted but the 64 cars could get lighter. Aluminum hood, fenders, doors, bumpers-brackets, door hinges then do the AFX package, stainless ateel k-frame,remove vent windows and the cranks, plexaglass back and front glass and side windows, gutted fiberglass dash no heater two van seats with aluminum brackets no back seats plus other hidden parts and these cars where close to 2800 lbs. All these things where factory available at that time and used. But if you want a street car with all the luxuries you got a barge, adds up quick.
[Re: cudaman1969]
#1700561
11/23/14 07:45 PM
11/23/14 07:45 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
My Savoy went across the scales at Norwalk last year with my 200# butt in the seat at 3610# ![](/ubbthreads/images/graemlins/whistling.gif) Iron block Aluminum heads,water pump/housing 60# of flywheel/clutch assy. 35# steel clutch can 113# Richmond 5-speed Dana 60 with spool(much lighter than the coffee can Power-Lock) Drum brakes all around(lighter than factory disc setup) I will be adding about 150# this winter with a roll bar in anticipation of my favorite local track reopening next year with all concrete full 1/4 mile ![](/ubbthreads/images/graemlins/biggrin.gif) Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1700562
11/24/14 06:33 PM
11/24/14 06:33 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
thanks Gus , they are the numbers I would like/hope to see - 100/150lbs lighter than my 68 . It does seem the Plymouths are always a little lighter than the Dodges
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 383man]
#1700564
11/25/14 12:05 AM
11/25/14 12:05 AM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
How much heavier were the wagons?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: Triggerfish]
#1700566
11/25/14 11:07 AM
11/25/14 11:07 AM
fullmetaljacket
about 40-50 Lbs on the body alone from Hardtop to Post sedan. Reinforcements on hardt's for strength in absence of the B-post as well as a heavier,larger shaped rear window. Sedans strength comes from their boxed triangular shape. Sought of like a gusseted box. Another maybe 15-25 lbs on trim exterior and interior and other amenities. Consoles included.
[Re: Triggerfish]
#1700568
11/25/14 12:37 PM
11/25/14 12:37 PM
Posts: 671 Los Osos, Ca
CKessel
Los Osos, Ca
My car is a hardtop plus its a 500 with all the trim and a/c. Maybe thats where the extra girth comes from.
Carl Kessel
#1700570
11/25/14 06:03 PM
11/25/14 06:03 PM
Posts: 3,916 usa
lewtot184
usa
500's were/are some of the heaviest of the early B's. Pretty cars though. By the way, keep in mind that the 64' B's are just a couple or so inches longer and a half or so inch wider than the 65's. That with a slew of bigger elaborate front bumpers make for some extra pounds.
The 62' are the smallest, but open for debate on their handsomeness or lack of it. I personally love them all. 63's are in between with the weight but start to look fantastic.
These days, someones gotta take what ever comes on the plate whether it's a hardtop or Post. They are becoming harder if not, impossible to find in great shape unless of course, if you go raid Mosher's stash out West. LOL.
x2, well said.
[Re: lewtot184]
#1700571
11/26/14 03:02 AM
11/26/14 03:02 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I can't tell you guys the weights, but my friends just had fun this weekend! I couldn't make it... This was the final! ![](http://arizonaautoscene.com/wp-content/uploads/2014/11/20141122-IMG_02571.jpg)
[Re: dvw]
#1700573
11/29/14 06:03 PM
11/29/14 06:03 PM
fullmetaljacket
DVW and I are seemingly neck and neck on the weight race. I think doing anymore to his car would disturb the beauty already in place. But if and when he decides, I'll be happy to share my Felix the cats magic bag of tricks as he probably would as well in the quest to break the 3000 LBS mark.
[Re: dvw]
#1700574
11/29/14 11:02 PM
11/29/14 11:02 PM
cudaman1969
fredericksburg,va
3120 w/o me. All steel including bumpers, except hood. 2 batteries, Mega block, 2 carbs, fire system. Like Lee says you can get them light. I positive I could get below 3000lbs if I wanted. Doug
What can i say, my favorite car. Very nice, it can get lighter with out messing with the looks
[Re: dvw]
#1700576
11/30/14 01:48 PM
11/30/14 01:48 PM
rattler
Crofton, Ky.
Hey Doug, what color is your 64? It looks like what I had in mind for my 64 Savoy wagon. Toxic Orange
