Re: anyone running a d1sc supercharger in their mopar?
[Re: Tobbe]
#1700374
11/26/14 12:51 AM
11/26/14 12:51 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
I had a D1X procharger. This is a previous race version of the D1 series. I had to make a custom brackets that fit to a motor plate. Worked great but the D1 series was too small for a 500 inch engine (about 10 lbs of boost) Great up to a 440 or a low deck.
Damn easy to drive around. Surprising for the power No worries with low rpm. Idles at 1000 rpm and 800 in gear Easy to drive around town. Even with 10 lbs is made tons of power and would smoke the tires at almost any rpm on the street.
Boost is amazing.
I did take some space in the front end with an intercooler. I would be easier in a Charger with the longer nose. The hardest part was fitting in the intercooler. A meth injection, would be much simpler, except you just have to remember to fill it up.
I probably should have stuck with the D1X as it works well but I got a deal on a used F1X so I built some new brackets.
FYI Cubic inches not required for a procharger setup. You can make crazy power with a stroked 383 or 440 with out any need for the additional stroke. The 500 inch is just what I had. It has even been suggested to destroke back to 440 as a better setup but I run it.
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#1700375
11/26/14 12:52 AM
11/26/14 12:52 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
Here are the brackets in the build phase One bracket for the front, one to support the back
[Re: Crizila]
#1700377
11/26/14 05:37 PM
11/26/14 05:37 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Something must be wrong with the S/C oe alingment them wide Azz belts are slipping.Look at the belt on mine an airwolfer S/C that is the standard for belt sizes on these cars and I do not think my belt slips(but I am gonna make sure it does not).
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
