Re: Excessive disc brake drag?
[Re: John_Kunkel]
#1700079
11/18/14 07:33 PM
11/18/14 07:33 PM
Posts: 10,672 Freeport IL USA
poorboy
Freeport IL USA
If I spin the wheel with a good hard spin, it will rotate on its own for about one revolution.
Sounds better than normal to me.
This really doesn't sound like much of a disc brake drag at all to me! Probably better then most! A disc brake drag is where you stop spinning the tire and it stops immediately, or you can barely get it to turn with the wheel. I think your chasing something you won't be able to cure with disc brakes. Gene
[Re: RapidRobert]
#1700081
11/18/14 10:07 PM
11/18/14 10:07 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Rick is that correct or not correct that you want the one pad to have some side to side clearance (so it can float)? And the other pad you want to bend the end L tabs so you have to snap it into place on the caliper?
Exactly.
Rick
[Re: Supercuda]
#1700088
11/20/14 12:23 AM
11/20/14 12:23 AM
Posts: 41 Northern MN
cedarmachine
Northern MN
Check the residuel valve. Most disc systems use a 1-3 lb valve for disc systems
Residual pressure valves are used in some DRUM setups, not disc.
If the master cylinder is lower than the brake calipers, you will certainly need residual pressure valves. That said, stock disc applications shouldn't need them.
