Re: Wow. Slugs are .151" in the hole
[Re: HotRodDave]
#1699780
11/17/14 03:17 PM
11/17/14 03:17 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You guys must have missed my other posts regarding this car. Here's my new cam card.
[Re: feets]
#1699781
11/17/14 03:43 PM
11/17/14 03:43 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Poor(pour) Man's High compression engine. Jack up one side of the car until the cylinder is straight up and down. Put a circle of thin card stock around a piston at TDC. It needs to be thin enough to fit between the piston and the cylinder wall. Drill several 3/8x 1/4 deep holes in the piston head and vacuum out the filings. These help anchor the DEVCON. Mix up some DEVCON and pour it in smoothing it as needed. Fill it to zero deck. Let it cure, remove the card stock, and repeat for each cylinder in that bank. Then lower the car and jack up and repeat on the other side. Let us know how this works out. Its only been tested in a Hypothetical Hemi so far. ![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: feets]
#1699783
11/17/14 05:25 PM
11/17/14 05:25 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Close enough. I would advance it 2-4 degrees to get a tad more TQ. That could help the turbo spool a tad quicker also becaus then the EX valve opens while there is a little more EX pressure. I would still run a higher ratio rocker to take advantage of the better flow at higher lifts.
