Removing the oil galley plug for Indy heads #169953
12/18/08 12:50 PM
12/18/08 12:50 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
The Indy heads require the external oiling lines that require you to use both of the oil holes at the rear of the block. The plugs have always been hard for me to remove, but for some reason, this time it's especially tough to get out. I don't want to strip it out trying too hard with an Allen wrench.
How have you guys done it?
Thanks in advance for any help.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Removing the oil galley plug for Indy heads [Re: 1968RR] #169954
12/18/08 01:39 PM
12/18/08 01:39 PM
Try using a hair dryer and warm the head up around the plug up for several minutes or more and then try it, make sure it gets hot to the touch first, not just warm
Re: Removing the oil galley plug for Indy heads [Re: Cab_Burge] #169955
12/18/08 02:03 PM
12/18/08 02:03 PM
after that melt some candle wax or blaster on them and wait a bit then try removing them.
