Re: Hurst Super Shifter 3...???
[Re: fourgearsavoy]
#1698276
11/20/14 02:50 PM
11/20/14 02:50 PM
Posts: 5,168 CT
GTX MATT
CT
I guess I meant is that the same bracket as for the comp plus?
[Re: GTX MATT]
#1698277
11/20/14 09:55 PM
11/20/14 09:55 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
The steel mounting bracket moves the shifter up and over to your leg where it feels natural. A Competition Plus will bolt up to the steel bracket because the bolt pattern is the same. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1698278
11/21/14 11:56 PM
11/21/14 11:56 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Back in the early 70's I bought a original super shifter after going to one of Dick Landy's clinics that he had at a local dodge dealership. At that time he had a super shifter in the challenger that he brought to show. I had a 68 roadrunner that was a street/strip car. The next day I ordered the shifter. It came with the L bracket that raised and set back the shifter into the car, major cutting was required. The shifter did not come with a reverse lock out, that came later , it was just a side plate that you could move up and down with a piece of threaded rod and a red round ball on it . After the roadrunner I put the shifter in a 63, 64, plymouth and then the 67 barracuda. I don't remember using the L bracket in the 63, 64 but the barracuda did not need it. Some cutting was required on the crossmember and floor towards the back of the original shifter hole. The proper shift bracket was needed to rotate the shifter to work. ![](/ubbthreads/images/graemlins/drive.gif)
[Re: rowin4]
#1698279
11/22/14 01:40 AM
11/22/14 01:40 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I thought the super shifter 3 was great just like you guys. And then I tried a Long shifter. The difference is night and day. I will never go back to a Hurst. ![](/ubbthreads/images/graemlins/Twocents.gif)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: donnie w]
#1698281
11/23/14 01:04 AM
11/23/14 01:04 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Here it is mounted in a b body. My reverse rod needs tweaking
