Re: 12V Source for Electric Choke Hookup? [Re: RapidRobert] #1697665
11/15/14 03:57 PM
11/15/14 03:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
yes there is no "choke pulloff" unless the piston inside there performs that function which is what I thought it did & that I was missing something cuz it came off too quick
The piston inside the choke housing does act as the pulloff and pulling off too quickly can be cured by simply turning the plastic outer housing toward the "RICH" direction (tightens the internal spring). The tighter the internal spring, the longer it takes the butterfly to fully open.
The loose fit of the pulloff piston in its bore also causes a slight vacuum leak which pulls fresh air into the choke housing to prevent overheating.
Re: 12V Source for Electric Choke Hookup? [Re: John_Kunkel] #1697666
11/15/14 06:17 PM
11/15/14 06:17 PM
John you are the man & when I get that 1406 on another running vehicle I will do just that. I will crank it rich(er) & find/solve why the piston ain't giving me the choke pulloff.
Re: 12V Source for Electric Choke Hookup? [Re: 440newport] #1697667
11/15/14 07:59 PM
11/15/14 07:59 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
The blue wire on the voltage regulator is lots closer to the carb than the fuse box. The amp draw from the choke is minimal, won't affect the ignition operation.
When I tried this on my truck it would over charge slightly. From 14.5 to about 15.5v at fast idle at the battery. When I removed the wire from the choke the voltage came back down.
I didn't see a voltage increase. Mine stayed about the same.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
