Page 4 of 4 1 2 3 4
Re: How Fast before Frame Connectors are needed ? [Re: dogdays] #1695770
12/05/14 06:03 PM
12/05/14 06:03 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
What I seem to remember from back in the day is movement at the welded/leaded line where the quarter panel joins the roof. In some cases the paint would actually flake off at the joint, and there'd be a noticeable bulge.
R.
Many times this wasn't a "torque" issue - the lead seams didn't get cleaned properly, and the acid based fluxes would actually eat the panels away under the paint. Seen a lot of cars with damage in that area that were low performance cars and could not have stress cracked that area.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: How Fast before Frame Connectors are needed ? [Re: Evil Spirit] #1695771
12/05/14 07:45 PM
12/05/14 07:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
" why didn't the factory use them instead of torque boxes that tie the sub-frames to the rocker boxes? You see a lot of factory installed (on all makes) torque boxes on high H/P cars and convertibles, but rarely (if ever) do you see factory installed sub-frame connectors"
The factory relied on the rockers mainly, the convertables had a 1/4 inch steel box tube inside the rockers with torque boxs tied in for strength. But controled flexing kept these cars from breaking up to last 100,000 miles in normal driving. But if hammered on, with todays roads, connecters are needed
Re: How Fast before Frame Connectors are needed ? [Re: cudaman1969] #1695772
12/06/14 02:20 AM
12/06/14 02:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I believe the factory went to the unibody to make the cars lighter. And when they did that in the early 60's there were no tires that really hooked much at all so they most likely did not worry about it much. I know a pics of the Ramchargers 63 shows no rollbar and a 70 Pro Stock Duster I saw just had the little round rollbar behind the seat. I dont know if either had any type of frame connectors but I would have thought a 70 Hemi Pro Stock Duster would have been hard on the car chassis without any type of rollbar to stiffen the car and they were 4-speed cars.
I can say I ran my 63 once when first on the road with my old mid 11 second 440 in the car and after I put the connectors and 6 point rollbar in the et really did not pick up any which surprised me. Ron
Page 4 of 4 1 2 3 4
