Page 2 of 4 1 2 3 4
Re: How Fast before Frame Connectors are needed ? [Re: gdonovan] #1695730
11/08/14 10:12 AM
11/08/14 10:12 AM
IN
ahy Offline
ahy  Offline
IN
My first modification was connectors... the car drove noticably better with them installed running a 318/auto. As several have said, these cars benefit from connectors regardless of power level.
Re: How Fast before Frame Connectors are needed ? [Re: ahy] #1695731
11/08/14 10:39 AM
11/08/14 10:39 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
My co-worker, John Soemer, ran his '67 GTX without them. His 'trick' was to park the car all week on jack stands so the body would settle back to straight. Eventually the axles broke and that ended the weekend short drives, but the body had stayed fairly straight. Obvious this is not a solution for everyone. Car was running just around 11 seconds with the last motor combo (and slicks of course).
Re: How Fast before Frame Connectors are needed ? [Re: Mattax] #1695732
11/08/14 11:27 AM
11/08/14 11:27 AM
gregsdart Offline
gregsdart  Offline
I just welded in a pair on my 65 street Dart, and forgot how important it is to support the front end in more than two positions to keep it from flexing when jacked and then winding up tweaked just a bit. As a result I have a very small paint chip on the left front fender where it meets the bottom of the body and the panels are tighter there than they were when painted.
I think we need to remember how old these car bodies are, and that support systems are even more important now than when new.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695733
11/08/14 12:01 PM
11/08/14 12:01 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Open your door, then jack up the front of the car and open the door. If you can tell a difference you definitely need the connectors. That being said; if you just do it anyway, you'll prevent future rattles and squeeks from popping up.
Yeah, it's got a smallblock.
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695734
11/08/14 12:34 PM
11/08/14 12:34 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Any car will benefit from them regardless power level. These unibodies flex a lot!!!!
Having said that, the FAST guys can go 10s without em on stock tires!
Re: How Fast before Frame Connectors are needed ? [Re: domingo] #1695735
11/08/14 12:52 PM
11/08/14 12:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The only issue I see with the formed style is that they are U-channel and not a piece of tube. Still better than a piece of tube hanging below the floor. Once the tube is installed it looks the same from the bottom anyway. I failed to put them in my street Challenger. Big mistake, even a small block 4 speed 12.50 car has tweeked the C-Pillar 1/4 to roof. I like to cut the bottom of the rear frame rail away. Drill a few spot welds and clamp the rail sides to the tube. Push the floor down to the tube at the front a 1/2" or so and it'll all be solid.
Doug
Re: How Fast before Frame Connectors are needed ? [Re: dvw] #1695736
11/08/14 12:56 PM
11/08/14 12:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
all done
Re: How Fast before Frame Connectors are needed ? [Re: dvw] #1695737
11/08/14 12:59 PM
11/08/14 12:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Bottom, disregard the roll cage and ladder bar stuff. Look at the fit to the floor pan.
Re: How Fast before Frame Connectors are needed ? [Re: dvw] #1695738
11/08/14 07:43 PM
11/08/14 07:43 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Just think how much stiffer the entire car would be by boxing in the subconnectors and tietie them into the rocker boxes. That would make a very large box structure that would tie the front to the rear and be stiff as heck. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: How Fast before Frame Connectors are needed ? [Re: 383man] #1695739
11/08/14 07:57 PM
11/08/14 07:57 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I put frame connectors and a 6 point rollbar in my 63 street/strip car. I feel the 6 point rollbar stiffened it more
In theory, I completely agree with this. With all the strengthening on 1 plane, front frame, rear frame, rockers and frame connectors. It's only as strong as a pick up truck which is the king of flex.
Connectors will transfer drag launching loads to the front frame but stop flexing?
Re: How Fast before Frame Connectors are needed ? [Re: Magnum] #1695740
11/09/14 10:06 PM
11/09/14 10:06 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Truth is, Factory should have tied the frames on any 426w, 440 & Hemi powered B-Bodies.
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695741
11/09/14 10:42 PM
11/09/14 10:42 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
After reading this thread I'm starting to realize my Mopar Performance bolt-in frame connectors are useless.
Would they be ok if I have a friend weld them in, or do they really need to come up through the floor?
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695742
11/09/14 11:13 PM
11/09/14 11:13 PM
Az
Crizila Offline
Crizila  Offline
Az
I was starting to wrinkle the fenders running high 11's. When I went to put in an 8 point cage, I added low positioned parallel bars between the hoop and front down bars. The front down bars sit directly over the front frame sections and the hoop sits over the rear frame sections. No more wrinkling and I run mid 10.s this way with no frame connectors.
Fastest 300
Re: How Fast before Frame Connectors are needed ? [Re: ProSport] #1695743
11/09/14 11:16 PM
11/09/14 11:16 PM
I have the Mopar bolt on ones on my '70 duster but,we welded them in same ones in 2 other friends cars..none of them come through the floor...
Re: How Fast before Frame Connectors are needed ? [Re: ProSport] #1695744
11/09/14 11:41 PM
11/09/14 11:41 PM
Puyallup, WA
Puyallup, WA
They're not useless, but they fall short of what your goal is with them. They don't need to come through the floor, but that would be the ultimate way to stiffen the floor section. Welding them in at each end would be a good idea, and will help a lot. From there, tying them to the floor somehow, mid-span is a good idea.
Re: How Fast before Frame Connectors are needed ? [Re: StealthWedge67] #1695745
11/09/14 11:58 PM
11/09/14 11:58 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Ok sounds good, I will get them welded on each end.
I've been saying all along that this particular car will not have a cage in it but I'm starting to think a 6 point bar might from turning into a pretzel as the motor will be easily capable of running 10's if I ever take it to a track. But the rear seat needs to be accessible.....decisions decisions.
Re: How Fast before Frame Connectors are needed ? [Re: ProSport] #1695746
11/10/14 01:01 AM
11/10/14 01:01 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
On a street car, to have rear seat access with a roll bar, at least from the pass side, run a diagonal bar from high on the pass side to low on the driver side, then install a bar behind the drivers seat from main hoop to diagonal bar. This supports the hoop side to side, gives a seat bar and a place to mount harness and also leaves a large opening on pass side to get in back seat..........just watch your head......LOL!!! I have also gone from the middle of hoop straight down to top of trans tunnel and then added seat bar behind driver. This leaves the whole pass side area open to get in back
Monte
Re: How Fast before Frame Connectors are needed ? [Re: ProSport] #1695747
11/10/14 02:36 AM
11/10/14 02:36 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mine are the bolt in bars that are welded and dont go through the floor. But I also have a 6 point rollbar welded in that I feel does more then the frame connectors do to stiffen the car. But I have had no problems. Ron
Re: How Fast before Frame Connectors are needed ? [Re: Thumperdart] #1695748
11/10/14 03:49 PM
11/10/14 03:49 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Speed really isn`t the issue it`s tying the frames to make a better working more rigid chassis.
Even a stock street car should have them if your going to beat on it.We see stock big block cars show cracks at the windshield piller/cowl area.
Re: How Fast before Frame Connectors are needed ? [Re: dvw] #1695749
11/30/14 05:27 AM
11/30/14 05:27 AM
USA MO
cdoublejj Offline
cdoublejj  Offline
USA MO
does adding in the tube cause any issue with factory carpet/interior?
UScar tool sells some laser cut pieces,
http://store.uscartool.com/66-70-B-Body-frame-connectors.html
Page 2 of 4 1 2 3 4
