Re: How Fast before Frame Connectors are needed ?
[Re: Mattax]
#1695732
11/08/14 10:27 AM
11/08/14 10:27 AM
Posts: 10,150 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I just welded in a pair on my 65 street Dart, and forgot how important it is to support the front end in more than two positions to keep it from flexing when jacked and then winding up tweaked just a bit. As a result I have a very small paint chip on the left front fender where it meets the bottom of the body and the panels are tighter there than they were when painted. I think we need to remember how old these car bodies are, and that support systems are even more important now than when new.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: ]
#1695733
11/08/14 11:01 AM
11/08/14 11:01 AM
Posts: 1,532 off the grid
340B5
off the grid
Open your door, then jack up the front of the car and open the door. If you can tell a difference you definitely need the connectors. That being said; if you just do it anyway, you'll prevent future rattles and squeeks from popping up.
Yeah, it's got a smallblock.
[Re: dvw]
#1695736
11/08/14 11:56 AM
11/08/14 11:56 AM
Posts: 10,047 MI, usa
dvw
MI, usa
[Re: dvw]
#1695738
11/08/14 06:43 PM
11/08/14 06:43 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Just think how much stiffer the entire car would be by boxing in the subconnectors and tietie them into the rocker boxes. That would make a very large box structure that would tie the front to the rear and be stiff as heck. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 383man]
#1695739
11/08/14 06:57 PM
11/08/14 06:57 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I put frame connectors and a 6 point rollbar in my 63 street/strip car. I feel the 6 point rollbar stiffened it more
In theory, I completely agree with this. With all the strengthening on 1 plane, front frame, rear frame, rockers and frame connectors. It's only as strong as a pick up truck which is the king of flex.
Connectors will transfer drag launching loads to the front frame but stop flexing?
[Re: Magnum]
#1695740
11/09/14 09:06 PM
11/09/14 09:06 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Truth is, Factory should have tied the frames on any 426w, 440 & Hemi powered B-Bodies.
[Re: ]
#1695742
11/09/14 10:13 PM
11/09/14 10:13 PM
Posts: 7,506 Az
Crizila
Az
I was starting to wrinkle the fenders running high 11's. When I went to put in an 8 point cage, I added low positioned parallel bars between the hoop and front down bars. The front down bars sit directly over the front frame sections and the hoop sits over the rear frame sections. No more wrinkling and I run mid 10.s this way with no frame connectors.
Fastest 300
[Re: ProSport]
#1695743
11/09/14 10:16 PM
11/09/14 10:16 PM
After reading this thread I'm starting to realize my Mopar Performance bolt-in frame connectors are useless.
Would they be ok if I have a friend weld them in, or do they really need to come up through the floor?
I have the Mopar bolt on ones on my '70 duster but,we welded them in same ones in 2 other friends cars..none of them come through the floor...
[Re: ProSport]
#1695744
11/09/14 10:41 PM
11/09/14 10:41 PM
StealthWedge67
Puyallup, WA
They're not useless, but they fall short of what your goal is with them. They don't need to come through the floor, but that would be the ultimate way to stiffen the floor section. Welding them in at each end would be a good idea, and will help a lot. From there, tying them to the floor somehow, mid-span is a good idea.
[Re: ProSport]
#1695746
11/10/14 12:01 AM
11/10/14 12:01 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Ok sounds good, I will get them welded on each end. I've been saying all along that this particular car will not have a cage in it but I'm starting to think a 6 point bar might from turning into a pretzel as the motor will be easily capable of running 10's if I ever take it to a track. But the rear seat needs to be accessible.....decisions decisions.
On a street car, to have rear seat access with a roll bar, at least from the pass side, run a diagonal bar from high on the pass side to low on the driver side, then install a bar behind the drivers seat from main hoop to diagonal bar. This supports the hoop side to side, gives a seat bar and a place to mount harness and also leaves a large opening on pass side to get in back seat..........just watch your head......LOL!!! I have also gone from the middle of hoop straight down to top of trans tunnel and then added seat bar behind driver. This leaves the whole pass side area open to get in back
Monte
[Re: ProSport]
#1695747
11/10/14 01:36 AM
11/10/14 01:36 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Mine are the bolt in bars that are welded and dont go through the floor. But I also have a 6 point rollbar welded in that I feel does more then the frame connectors do to stiffen the car. But I have had no problems. Ron
[Re: Thumperdart]
#1695748
11/10/14 02:49 PM
11/10/14 02:49 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Speed really isn`t the issue it`s tying the frames to make a better working more rigid chassis.
Even a stock street car should have them if your going to beat on it.We see stock big block cars show cracks at the windshield piller/cowl area.
