Re: Anyone running a mild hydraulic cam 440 stroker? [Re: codfish] #2565488
10/17/18 05:09 PM
10/17/18 05:09 PM
NC
70charger512 Offline
#1 Thread Starter
#1 Thread Starter
NC
Originally Posted By codfish
493" RB
11-1 comp with stock RPM heads
cam is a hydraulic flat tappit scott brown 540 lift, with 265 ish duration (can't remember exact specs)
850 bigs carb
rpm intake
3800 stall
3:73 dana 60
Runs 11 flat @ 120 in a 3800 lb Dart.
codfish
Im gonna need every detail of ur build laugh2 because im planning on doing almost the exact same thing, except w tko600. Dyno numbers? And cam operating rpm range.
Re: Anyone running a mild hydraulic cam 440 stroker? [Re: 70VcodeCoronetRT] #2565504
10/17/18 05:40 PM
10/17/18 05:40 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I'm running a CompCams XR274R solid roller in my 496" in my '60 NewYorker.
Idles great, but the longram intake manifolds make both carbs do their own thing when running, so it's a bit of hanful at times, pushing against the stock convertor quite a bit.
274/280 Adv. duration.
236/242 dur, at .050"
0.564" / 0.57" lift.
Re: Anyone running a mild hydraulic cam 440 stroker? [Re: 70charger512] #2565516
10/17/18 05:54 PM
10/17/18 05:54 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
493" RB
850 bigs carb
rpm intake
3800 stall
3:73 dana 60
codfish
his cam is way bigger than what you were considering.
Codfish, what RPM do you shift at and do you run it on pump gas?
Re: Anyone running a mild hydraulic cam 440 stroker? [Re: krautrock] #2565540
10/17/18 06:44 PM
10/17/18 06:44 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
493" RB
850 bigs carb
rpm intake
3800 stall
3:73 dana 60
codfish
From what he posted its very close, except it has slightly less duration and .540 lift while mine has .494...
Re: Anyone running a mild hydraulic cam 440 stroker? [Re: 70charger512] #2565543
10/17/18 06:48 PM
10/17/18 06:48 PM
How about switching to a set of true 1.6 ratio or higher rocker arm ratio? work up
That can really fool the motor, especially at idle and the lower RPM below 2500 RPM up
Re: Anyone running a mild hydraulic cam 440 stroker? [Re: 70charger512] #2565550
10/17/18 06:54 PM
10/17/18 06:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
493" RB
850 bigs carb
rpm intake
3800 stall
3:73 dana 60
codfish
Im pretty sure it’s 265@.050....... so about 40 degrees more duration than the voodoo 268....... and pretty far from what most think of when they’re talking “mild” cams.
Re: Anyone running a mild hydraulic cam 440 stroker? [Re: 70VcodeCoronetRT] #2720636
12/01/19 12:54 PM
12/01/19 12:54 PM
Sweden
Mopar493 Offline
Mopar493  Offline
Sweden
This is an old thread but anyway, i have built a 493 stroker 10,04:1 compression ratio, Mopar 440-77 block 030 over, Eagle 4,150" crank, Eagle h rods 6,760", Mahle forged flattop pistons 8cc valve relife and 040" under deck, Comp cam xe275hl (231/237@050)and 0,525 lift both, Edelbrock e-street 84cc cylinder heads, Edelbrock rpm intake, Edelbrock 800cfm avs carb. Like i said 10,04:1 scr and theoretical dynamic compression with this cam 8,05:1, cylinder preassure 185psi, the engine running great here in Sweden at sea level without any detonation with 98 octane fuel(our 98 is same your 93 in the Usa, so pump gas), i have run it this summer for about 500 problem free miles. It has tremendous torque and make my over 4000 lbs Chrysler 300-64 to move like a bullet from a gun when i step on the throttle, torque is king on the street. Drive line is a 727 streetfighter, Tci break away 2400 stall, 3" drive shaft with 7290 universal joint, 8 3/4 with Eaton true trac helical differential and 3:55 gears and also one adjustable pinion snubber. I see all suggestions of cam shafts in this thread is much bigger than what im running in my engine with zero detonation with initial ignition at 16 degrees and full out 34 degrees at 3000 rpm, fuel same your 93 octane and in Sweden at sea level, my point is that its working to drive a pretty mild cam and get alot of torque, the important thing here is the dynamic compression ratio, in other words when the intake valve close after bdc, it should not be over 8,5:1 with aluminium heads and pump gas, you loose a point with aluminium heads. This is a great engine and idles smootly at 900 rpm and 15 hg/inch of vacuum.
