Page 3 of 3 1 2 3
Re: How much gain for heads? [Re: mopower440] #1694619
11/07/14 12:24 AM
11/07/14 12:24 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Thermo-quad needs an adapter on an RPM and with the wider area before it drops down around the carb it will be harder to find an air cleaner.
Re: How much gain for heads? [Re: mopower440] #1694620
11/07/14 12:34 AM
11/07/14 12:34 AM
Will a thermoquad even bolt up to the RPM intake?
You'd need the alum adapter plate to mate the spread bore TQ to the square bore flange rpm intake which'd add that much more height to the situation. I dont remember right offhand how thick (tall) it is
Re: How much gain for heads? [Re: mopower440] #1694621
11/07/14 08:06 PM
11/07/14 08:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Ok, then while were at it, lets fix the intake problem first. I know the edelbrock performer RPM is the one advised the most but i have been told by many that it will not fit under the hood in a 440 dart. This sucks. Is there possibly another intake out there that will fit and be even close to the performance of the edelbrock performer rpm?
Go to Edelbrock's website. Select the intake manifold you're looking for. They list the height of the intake manifold.
Measure your intake manifold.
Stick a lump of clay, paper cup, or other squishy thing on top of the air cleaner.
Close the hood.
Open the hood at see how tall the squishy thing is now. That is your hood clearance.
Be sure to add a little room for engine movement assuming it's not on solid mounts.
- Stu Harmon
Re: How much gain for heads? [Re: feets] #1694622
11/07/14 10:02 PM
11/07/14 10:02 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
Close the hood.
I can do that. How do i go about measuring my stock intake as its bolted on the engine running the car currently?
Re: How much gain for heads? [Re: mopower440] #1694623
11/07/14 10:08 PM
11/07/14 10:08 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
the RPM will be about 1.5" to 1.62" taller than stock.
Re: How much gain for heads? [Re: BSB67] #1694624
11/07/14 10:46 PM
11/07/14 10:46 PM
middle Tennessee
middle Tennessee
anyone know how tall the adapter would be that mounts the thermoquad to the RPM?
Re: How much gain for heads? [Re: mopower440] #1694625
11/07/14 10:58 PM
11/07/14 10:58 PM
The Mr Gasket piece "MRG1932" is 3/4" thick plus the slight addition of an additional gasket. $19.95 + ship on Mancini racing
Re: How much gain for heads? [Re: RapidRobert] #1694626
11/07/14 11:14 PM
11/07/14 11:14 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Will a TQ bolt directly to an RPM intake? I didn't know if the adapter was necessary.
- Stu Harmon
Re: How much gain for heads? [Re: feets] #1694627
11/07/14 11:17 PM
11/07/14 11:17 PM
Yes cuz the RPM is a square bore flange intake
Re: How much gain for heads? [Re: feets] #1694628
11/07/14 11:18 PM
11/07/14 11:18 PM
middle Tennessee
middle Tennessee
Not sure if it will but i 'think' the adaptor is needed because the thermoquad is a spreadbore carb and the RPM is a squarebore intake..
Re: How much gain for heads? [Re: mopower440] #1694629
11/10/14 02:42 PM
11/10/14 02:42 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I answered the question above, apparently no one reads my posts
Re: How much gain for heads? [Re: HotRodDave] #1694630
11/10/14 05:37 PM
11/10/14 05:37 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I built a '72 Valiant 4dr sedan with a RB 493 stroker, using Eddy heads and a Perf RPM intake. The stock hood fit fine using a K&N drop base air cleaner assembly.
Page 3 of 3 1 2 3
