Page 1 of 3 1 2 3
Need a rotisserie....have questions. #1694440
11/04/14 08:11 PM
11/04/14 08:11 PM
Texas
carcrazyguy Offline OP
Texas
I need to get a rotisserie for the 73 Barracuda. I am looking at the Auto Twirrler brand. More specifically the Auto Twirler Plus. Anyone use one of those? Are there any accessories that I should consider along with the rotissirie?
Re: Need a rotisserie....have questions. [Re: carcrazyguy] #1694441
11/04/14 08:26 PM
11/04/14 08:26 PM
Waddell AZ
azblackhemi Offline
azblackhemi  Offline
Waddell AZ
I bought an Auto twirler at the end of last year. I finally put a car on it this last week. Apparently the company was sold and has had some quality control issues. There is a large bolt that goes through the main upright with a large thick washer to hold it in place safely. On mine the holes were drilled on an angle instead of straight through so the washer wouldn't fit in the hole. I had to plasma cut out over a quarter inch of each hole to make it work. My other problem is I put a 70 Challenger convertible on it and can't get it perfectly balanced no matter where I adjust it. I was told the lower center of gravity of a vert makes it tough. The steel and welds do look like it is made very well but so far I'm really not completely satisfied although it will work for me just not as well as I hoped. We'll see how it goes with the next car on it.
Re: Need a rotisserie....have questions. [Re: carcrazyguy] #1694442
11/04/14 09:27 PM
11/04/14 09:27 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Can't speak for Auto Twirler but can tell you my Whirly Jig is outstanding. My painter hasn't stopped trying to buy it from me since I sent my car to him on it (he ownes the other brand)
http://www.whirlyjig.com/
Good luck whatever you decide
Re: Need a rotisserie....have questions. [Re: AAR#2] #1694443
11/04/14 10:13 PM
11/04/14 10:13 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I build rotisseries in Canada for the market up here. I've made it a point over the years to look at all of the higher end (US-made) units and my favorite by a long shot is the Whirly-Jig. A little more money maybe but better than anything else by leaps and bounds.
Here's a prime example ... this unit doesn't even have a car on it and its already sagging at the ends of the arms !!! And this is their top of the line model !!!
As for:
This is absolutely true of convertibles. To get them to balance well you need mounts that raise the car up a bit. On ragtops the car has to be able to be raised so that the floor is almost level with the pivots!
Re: Need a rotisserie....have questions. [Re: Stanton] #1694444
11/04/14 11:05 PM
11/04/14 11:05 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
I did quite a bit of research on the better known rotos before I bought mine and though most had their supporters and detractors, no one and I mean no one had a bad thing to say about the Whirly-Jig. Ultimately, thats what I bought and I've not looked back since.
As an added bonus, when you're done with it, you'll have no problem selling it, that's for sure.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Need a rotisserie....have questions. [Re: 5wndwcpe] #1694445
11/05/14 12:17 AM
11/05/14 12:17 AM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
I've also got a whirly-jig pro. best money I've ever spent on tools or equipment.
Re: Need a rotisserie....have questions. [Re: 5wndwcpe] #1694446
11/05/14 02:46 AM
11/05/14 02:46 AM
Texas
Texas
Thanks everyone for the info!
When I am done...right! We all know once they get torn apart, they may not go back together. Plus this is a test to see if we can really do a car from start to finish. If we can I have 2 more to do before I think about stopping.
Re: Need a rotisserie....have questions. [Re: carcrazyguy] #1694447
11/05/14 10:30 AM
11/05/14 10:30 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Another vote for the Whirley Jig.
Bought mine several years ago,,,,,ZERO complaints
Re: Need a rotisserie....have questions. [Re: carcrazyguy] #1694448
11/05/14 12:35 PM
11/05/14 12:35 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I bought a auto twirler in 2005. At the time I didn't know anything about them and decided to go up to the west side of Indy to pick it up so I could see cars mounted on one that they had in there shop. I learned everything I needed to know by visiting there shop. It was a good sized welding shop with like 10 or more employees and they were very nice to me, showed me all around there shop. Sent me a tie shirt in the mail like 6 months later.
I did not buy any mounting brackets from them, my E body was easy to mount using the front bumper mounting and the rear spring hanger hole.
I did buy off road wheels which were a waste of money as I never used them.
I have had 3 cars on mine so far and it has been plenty good enough for me. Mine went to the body shop and back in my trailer with the car mounted on it.
I turned my car 90° on mine, there's no reason to turn it upside down.
Re: Need a rotisserie....have questions. [Re: Challenger 1] #1694449
11/06/14 01:13 AM
11/06/14 01:13 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I made mine from a friends plans he bought from a magazine. Cost me $240 in steel and a few hours of cutting and welding. No issues with my 69 GTS on it...
JB Rhinehart, Realist
A-Body's RULE!
Re: Need a rotisserie....have questions. [Re: Rhinodart] #1694450
11/06/14 01:55 AM
11/06/14 01:55 AM
Texas
Texas
Looks like it will be the Whirlyjig Pro Plus. Looks like that will keep me from having to order any extra accessories. I do like the body/frame stiffener but not sure that would be needed for my hardtops.
Re: Need a rotisserie....have questions. [Re: carcrazyguy] #1694451
11/06/14 12:18 PM
11/06/14 12:18 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You made the right choice !
Re: Need a rotisserie....have questions. [Re: Stanton] #1694452
11/06/14 05:13 PM
11/06/14 05:13 PM
Texas
Texas
Called them today to order the Pro Plus and the mount stiffer kit. It should be here in 7-10 days!
Re: Need a rotisserie....have questions. [Re: carcrazyguy] #1694453
11/06/14 05:47 PM
11/06/14 05:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have an auto twirler plus and have been more than happy with it.
I made my own mounting brackets.
Re: Need a rotisserie....have questions. [Re: Morty426] #1694454
11/06/14 05:54 PM
11/06/14 05:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Waste of money unless you have a ragtop. It won't add to resale unless the buyer has a ragtop. My advice would be to cancel that item and save the $$. That thing is easy enough to make or have made locally if its ever needed.
Re: Need a rotisserie....have questions. [Re: Stanton] #1694455
11/06/14 06:00 PM
11/06/14 06:00 PM
Texas
Texas
It was $55 and I ( ) will have them if I ever need them.
Re: Need a rotisserie....have questions. [Re: carcrazyguy] #1694456
11/06/14 06:42 PM
11/06/14 06:42 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I suppose $55. isn't the end of the world.
Re: Need a rotisserie....have questions. [Re: Stanton] #1694457
11/07/14 02:19 PM
11/07/14 02:19 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I got a whirly jig pro model, we picked it up at the nats back in 92 and it still looks and works like the day we bought it. No doubt in my mind they are the best out there I also got the wheels and hitch kit to roll it off road, nice for moving on my dirt/gravel driveway.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Need a rotisserie....have questions. [Re: carcrazyguy] #1694458
11/07/14 03:29 PM
11/07/14 03:29 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
You won't regret the Whirly-Jig. I bought one used here on Moparts, and love it!
Re: Need a rotisserie....have questions. [Re: JDMopar] #1694459
11/08/14 08:38 PM
11/08/14 08:38 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Whirly-Jig here.
Master, again and still
Page 1 of 3 1 2 3
