Re: Trick Flow introduces BBM heads
[Re: 1baddart]
#1694183
11/05/14 06:12 PM
11/05/14 06:12 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Good lord do I hope they come out with a good alternative for us bigger cube guys. Something to give indys or even b1s a run for their money!
Exactly......where is the NEW head that has at least as much or MORE potential than the B-1 PSO, is more user friendly and you can actually GET......I will take 2 sets right now.......LOL!!!
Monte
[Re: BradH]
#1694184
11/05/14 06:14 PM
11/05/14 06:14 PM
They make a head for the big cube guys--its called a Hemi Isn't Trick Flow Summits house brand anyway? So isn't this a Summit head? Source has proven that the race to the bottom --NOT the top is the one with the big numbers on sales--at least back when they were $895 a pair The guys that get back there with an aluminum head that will fit existing pistons/combos etc like the old Eddy/Sidewinder etc will be KING Hey that is a good name for a $795 a pair head Until then Sidewinders are Excellent quality and get my business--Marsh has been EXCELLENT in providing those heads fast as UPS can bring them and our shop is putting them in about every build we do --
[Re: Monte_Smith]
#1694186
11/05/14 06:40 PM
11/05/14 06:40 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
From their FB page. Quote:
Trick Flow Specialties: $1800-$1900 range assembled for the pair.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#1694187
11/05/14 07:00 PM
11/05/14 07:00 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
Brian, have you any idea how these heads compare to the CNC Stealths ? I think it is great there is a company stepping into the ring for Mopar , will maybe bring the others up a step with competition . As said before the BB market is primarily 450-510ci making to 650ish HP .You do put your toe in the water at the shallow end first - then go deeper . Not jump in the deep end hoping for the best .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: BradH]
#1694188
11/05/14 07:43 PM
11/05/14 07:43 PM
Do You Have, or have you had a set of these Heads ???
Any chance you're related to the late Senator Joseph McCarthy?
If the guy is saying:
"Unlike every single mopar head out there, these heads are a TRUE bolt on! And they actually flow as advertised...and they have upgraded hardware."
Isn't it reasonable to ask if he actually has/had one of these heads, or is he just going by the promo materials ?
If someone is emphatically stating that they are a "TRUE bolt on deal", it would be nice to know if THEY have actually bolted them on anything !! I was ready to buy Source heads, then I heard about the Sidewinders, and now these sound good.....just looking for first hand info.
[Re: ]
#1694189
11/05/14 08:28 PM
11/05/14 08:28 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
My guess is that as Brian is a professional engine builder he wouldn't say they are a true bolt on unless he was positive they were. I would trust his statement to be factual
[Re: ]
#1694192
11/06/14 01:43 AM
11/06/14 01:43 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I think the expression " have to follow the chain of command " makes it obvious enough. Command decisions are made a pay grade or two above the ground troops , as it were. And to disobey them will have you standing tall before the man. And that is no place to be.
[Re: Twostick]
#1694193
11/06/14 02:18 AM
11/06/14 02:18 AM
Posts: 2,644 North Carolina
sasquatch
North Carolina
Interesting 1.78 Exhaust valve.... The one article said starting at 1800 bucks ok not bad on that front. The intake looks pretty nice although I do wish they could offer it in a 1 piece deal with the valley cover. Ok now to They look alright to me. Not world beaters but I am pretty sure we (and a lot of other people) could blow the bottom end out of a stock block with them. What is not to like? Some of you guys need to go back to the days when McCandless ported 452s were as GOOD AS IT GOT and they cost almost as much as these 20 years ago. And if it cracked oh well. Now it seems like heads are coming out of the woodwork. GOOD. We can no longer be held hostage. Competition between the manufacturers will be good for everyone looking to buy heads of all kinds. What we need is BLOCKS. We can make any aluminum head on the market run over the crank. We just shipped a 655 Indy wedge that made almost 1100 on pump gas. HOW much do you want? We (and others have many ways to build about anything you want) Write the check and you can have one to. All this talk about what is and is not a race head is nuts. How fast do you have to go to be called a race head? How much power does it have to make? Why not just bolt two big hair dryers on it or Call up Charlie Buck and spray the bearings out? All it takes is $$$$$. Then we have our Mopar guys. Most of them are not wiping their bums with Ben Franklins. As someone who has sold more dang mopar heads than you could fit in a semi truck, I can tell you that $$$$ is ALWAYS the limiting factor for any engine build. Bang for the buck always matters. I am happy to see another company throw their hat in the ring. I hope they do offer other parts. Hey some 500 cfm heads would be sweet if they cost under 10grand...so guys enjoy the show. I NEVER would have guessed 10 years ago even that we would have all these choices. ALL of these heads are filling in gaps and have markets. It may not be what you are looking for but the guys that buy them are funding the R/D that will pave the way for bigger and badder stuff to come. Todd
[Re: Twostick]
#1694194
11/06/14 02:25 AM
11/06/14 02:25 AM
BradH
If those chambers can get the burn rate down to where total timing is in the hi 20's you can say goodbye to cap walk and other assorted destructive forces.
That alone would be worth the price of admission.
Kevin
Those chambers aren't that much different from other heart-shaped chambers that still end up with 34 - 36 degrees advance for best power. No magic there from what I see.
[Re: 1baddart]
#1694195
11/06/14 04:49 AM
11/06/14 04:49 AM
Posts: 345 Nebraska
451Cuda
Nebraska
I had been setting aside money for B1 MC's...may hold off and see what the race version looks like.
[Re: RAMM]
#1694197
11/06/14 10:07 AM
11/06/14 10:07 AM
Posts: 1,051 The Great White North
RAMM
Also the 1.78" exhaust size is a smart move IMO. No need for a big heavy 1.81" valve. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: GTS340]
#1694198
11/06/14 11:19 AM
11/06/14 11:19 AM
Posts: 494 IL
EchoSixMike
IL
Are you considering them an EZ based on the similar flow numbers? Having 240cc intake runners after being CNC machined they are still 30cc smaller than the as cast EZ. I wonder how the CSA compares to the EZ.
Someone else mentioned this but I'll add my 2 cents.
The EZ is designed for use as a MW size port. Which is fine, but if you're running a small engine not ideal. A better designed port makes more sense IMO than just port volume. Kinda like the Chapman Stage 6's, except without the incredible price. Yes, I know why they cost that much, but that has little to do with them being outside the budget of most everyone.
The smart head producers these days cast the heads with a ton of meat and then let the CNC tooling cut all the chambers/ports/etc. This gives far better results than trying to cast as-finished heads. For this reason alone, this is a better head than the other stuff on the market, where it's port volume makes sense.
I'm hoping they do a max wedge port, something like a -1 killer, that should go 400'ish at .700. And then a full boat head, going as tall as they can, the problem there is blocks. 4.900 bore space? Cool, but why not just run a BBF w/ a Thor head, since that's what you just built anyways?
The issue is, what's the market? A B-1 killer? What's the most you can get out of a 4.8 B/S design? What would be the purpose? For any outlaw/10.5/275/whatever stuff, why not just run a hemi with a turbo or screw? The fuel/alky guys have already done the work there. Rules? OK, if you're racing a rule book, you need to build to the rulebook. S/F.....Ken M
[Re: RAMM]
#1694199
11/06/14 12:31 PM
11/06/14 12:31 PM
Posts: 6,568 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
This has nothing to do with cap walk-unless you exceed the timing required and get into pre-ignition and detonation. J.Rob
I have a buddy in the R+D biz that has the technology to data log cylinder pressure in real time and his research shows that detonation is happening long before you can hear it or see it in power data on a dyno when using commonly accepted total advance #'s. The pressure spikes started as you approached 30 deg and got progressively higher as the timing curve advanced to total.
I draw a similar conclusion based on the fact that there are guys on here that run boosted stock block combos at almost double the power levels that seem to beat the mains out of a stock block NA combo and the only thing I see different other than the boost is the timing curve. Mid 20's max. Little to no cap walk.
It is no accident that modern chambers like the Gen III Hemi or the LS are all done timing wise in the low 20's or less.
Kevin
[Re: 1964superstock]
#1694201
11/06/14 03:37 PM
11/06/14 03:37 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
That chamber will help timing requirements some but not drastically, mabey bring it down a couple degrees VS eddy, stealth, sidewinder, pro comp... Good chambers can make a big difference as was noted on the new Hemi and LS motors, even on the old small blocks you could bring the timing down a ton going from an X J or whatever open chamber to a magnum with a good tight quench.
