Page 1 of 9 1 2 3 4 5 6 7 8 9
Trick Flow introduces BBM heads #1694123
11/04/14 11:31 AM
11/04/14 11:31 AM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
Glad to see them getting into the Mopar market.
http://bangshift.com/general-news/new-pr...w-option-wedge/
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Trick Flow introduces BBM heads [Re: BBR] #1694124
11/04/14 11:43 AM
11/04/14 11:43 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Good to see! The chamber looks pretty slick, says the port is in the stock location.
I kind of wished they would've went with a canted valve/twisted wedge like they did with the SBF
Re: Trick Flow introduces BBM heads [Re: WO23Coronet] #1694125
11/04/14 11:52 AM
11/04/14 11:52 AM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
Looks like they have an intake manifold as well.
RMRW 2018
RMRW 2020
Re: Trick Flow introduces BBM heads [Re: BBR] #1694126
11/04/14 12:11 PM
11/04/14 12:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
wonder what they cost???
Coming soon!!!!
Re: Trick Flow introduces BBM heads [Re: BBR] #1694127
11/04/14 12:12 PM
11/04/14 12:12 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Looks like they flow what an MCH Eddy does. Price point will interesting. Minimum bore of 4.320 kind of rules out use on a 383B, but ought to work great on a 400B.
Re: Trick Flow introduces BBM heads [Re: 64Post] #1694128
11/04/14 12:23 PM
11/04/14 12:23 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Looks like another nice option. Looks a lot like a INdy Ez from the pictures. Sweet! Todd
Re: Trick Flow introduces BBM heads [Re: sasquatch] #1694129
11/04/14 02:19 PM
11/04/14 02:19 PM
SoCal
Brian Hafliger Offline
SoCal
We are a TrickFlow dealer so is anyone needs any info just PM or email me...they will be out by Spring 2015.
We will have a few castings soon to test with...I will keep you guys posted on this.
Brian
Brian Hafliger
Re: Trick Flow introduces BBM heads [Re: Brian Hafliger] #1694130
11/04/14 02:29 PM
11/04/14 02:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
looks like a breath of fresh air; no pun intended. thanks trick flow!
Re: Trick Flow introduces BBM heads [Re: WO23Coronet] #1694131
11/04/14 02:39 PM
11/04/14 02:39 PM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
For their initial offering, I for one am glad they did not do something that required special parts.
AFR just did that with their new BBF head. The head looks to be fantastic. But it requires special pistons and intake so they effectively chopped their available customer base to smithereens.
RMRW 2018
RMRW 2020
Re: Trick Flow introduces BBM heads [Re: lewtot184] #1694132
11/04/14 02:43 PM
11/04/14 02:43 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
It's interesting to see that the advertised flow numbers are better then what Edelbrock advertises for the Victors but don't require offset rockers. I am excited to see what some of the cylinder head porting wizards that lurk around here can do with them.
Re: Trick Flow introduces BBM heads [Re: CTD5.9] #1694133
11/04/14 03:12 PM
11/04/14 03:12 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
So in the list of BB head hierarchy where would they land??? Better than my SR 295CNC ? just curious..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Trick Flow introduces BBM heads [Re: Eric] #1694134
11/04/14 03:34 PM
11/04/14 03:34 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
So in the list of BB head hierarchy where would they land??? Better than my ported 516's?? just curious..
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Trick Flow introduces BBM heads [Re: Eric] #1694135
11/04/14 03:42 PM
11/04/14 03:42 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
my EZ heads with standard rocker flowed 335@.6, 355@.7 but I guess the EZ port was taller than those
Re: Trick Flow introduces BBM heads [Re: sixpackgut] #1694136
11/04/14 04:05 PM
11/04/14 04:05 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
It seems like they flow better at low lifts than the Indy EZs, something that might be good for us street/strip guys with cams in the mid-.500 range?
Re: Trick Flow introduces BBM heads [Re: BBR] #1694137
11/04/14 04:07 PM
11/04/14 04:07 PM
The Great White North
RAMM Offline
RAMM  Offline
While this is true, by NOT changing valve position and or angles this head is nothing more than another Eddy Performer/440 Source/Sidewinder offering. Will it be leaps and bounds better than the aforementioned? Doubtful. The chamber does look good as does plug position but it's difficult to tell from here. I wish they offered a RR version with the intake valve moved towards the block centerline. Hopefully the angled plugs cause a minimum amount of headaches for the end user.
They obviously feel it is a superior head aimed at the intended market. I hope it is. Always nice to have another option. Also price point will be the make it or break it factor-especially with us cheap Mopar guys. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Trick Flow introduces BBM heads [Re: RAMM] #1694138
11/04/14 04:10 PM
11/04/14 04:10 PM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
I read $1800-1900 for a complete pair.
RMRW 2018
RMRW 2020
Re: Trick Flow introduces BBM heads [Re: RAMM] #1694139
11/04/14 04:12 PM
11/04/14 04:12 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Those look like a nice piece, I want to hear pricing info.
Re: Trick Flow introduces BBM heads [Re: OUTLAWD] #1694140
11/04/14 04:38 PM
11/04/14 04:38 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Re: Trick Flow introduces BBM heads [Re: Eric] #1694141
11/04/14 04:48 PM
11/04/14 04:48 PM
tboomer Online work
tboomer  Online Work
Glad to see a new head on the market! But I will stick with my Victors.
Re: Trick Flow introduces BBM heads [Re: WO23Coronet] #1694142
11/04/14 05:04 PM
11/04/14 05:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Hard to twist the wedge with a rocker shaft.
Sure seems a waste with so many BB heads out there but sooooo many more SB motors got produced.
BTW They could have done a twisted wedge with magnum heads and made it flow almost as much on a much lighter, smaller engine that already had good plug location
