Page 2 of 3 1 2 3
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693428
11/02/14 02:10 AM
11/02/14 02:10 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Thanks for the help guys!
This thing is actually a Unisteer Low-Flow pump 8060300
Hopefully it will work with my Hydroboost
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: RylisPro] #1693429
11/02/14 02:29 AM
11/02/14 02:29 AM
So Cal
autoxcuda Online content OP
autoxcuda  Online Content OP
So Cal
Just laying out my cache of power steering stuff
Top left: 6" diameter Aluminum V-groove pulley for press on 0.662 shafts.
Top pump: is a cast iron bare pump without reservoir. Exterior looks almost identical to the aluminum one w/reservoir attached. I believe the reservoir would interchange between the two.
Left pump: is aluminum with attached reservoir.
Center: pump is KRC p/n 20-0157 and KRC adapter p/n 30000 for a Chevy Circle Track car.
Lower Right: Remote aluminum reservoir has internal baffles and has a roll bar mount bracket attached to it.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693430
11/02/14 02:32 AM
11/02/14 02:32 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Are these other pumps? What's the one on the bottom?
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: RylisPro] #1693431
11/02/14 02:36 AM
11/02/14 02:36 AM
So Cal
So Cal
Seems the KRC pump p/n 20-0157 and KRC adapter p/n 30000 I have has a different smaller bolt pattern than the aluminum one with the attached plastic reservoir.
Question is what bolt pattern are the Mopar KRC mounting plates made for???
This KRC pump has had the thread holes in the body drilled out removing the threads to fit bigger bolts
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693432
11/02/14 02:37 AM
11/02/14 02:37 AM
So Cal
So Cal
Aluminum Pump with reservoir has larger bolt spacing.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693433
11/02/14 02:38 AM
11/02/14 02:38 AM
So Cal
So Cal
Cast iron bare pump without reservoir has same bolt spacing as aluminum pump w/reservoir
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693434
11/02/14 02:39 AM
11/02/14 02:39 AM
So Cal
So Cal
Backside of all the pumps.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693435
11/02/14 02:44 AM
11/02/14 02:44 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would bet the KRC matches the KRC bracket. Man Steve I didn't know you were a closet PS pump hoarder.
Mopar to the bone!!!
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693436
11/02/14 02:48 AM
11/02/14 02:48 AM
So Cal
So Cal
I would bet the KRC matches the KRC bracket....
Yes, the KRC bracket came with that pump.
I've got about $40 tied up in what you see collected for over 10 years.
...Man Steve I didn't know you were a closet PS pump hoarder.
Wanna see a dozen sway bars... a couple crates full of new suspension parts...F/M/J, 66-69 B, 70-72 E, 73 C, 73-up A: body disk spindles...
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693437
11/02/14 03:28 AM
11/02/14 03:28 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I just started the electric PS conversion for my AAR. I have the motor attached to the column and have to measure and weld the shafts. Fits nicely under dash and will use the manual box. Will be under $200 including the controller and will make the Gen3 Hemi conversion easier. WIll do a write up when done.
http://forums.vintage-mustang.com/mod-custom-forum/787114-best-200-mod-ever-eps.html
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: HUSTLESTUFF] #1693438
11/02/14 03:36 AM
11/02/14 03:36 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Steve I bet they have both sizes from KRC whether its an aluminum pump or iron. If you look at the Mopar KRC bracket it has 2 holes for the bottom bolt.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693439
11/02/14 09:35 PM
11/02/14 09:35 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I'm using a Profile iron body pump from Speedway. This is a carbon copy of the aluminum KRC unit. I used stock brackets to mount mine up. The rear mount I did have to shim with a few washers and I had to modify a chevy alternator bracket for the adjustment arm, but otherwise, nothing trick to get it mounted.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693440
01/18/15 08:31 PM
01/18/15 08:31 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
So for the Unisteer low flow pump that I have in my pic above, I am pretty sure that I have this control valve installed which enables the GM type II pump to be used with a Ford rack and pinion.
According to this article
http://www.hotrod.com/how-to/chassis-suspension/ccrp-1304-gm-power-steering-secrets/
there is just a size difference in the hole of the fittings stock .150 on left and low flow .093 on right
There is also a small hole one the side of the fitting which is a bypass hole "B"
http://www.archivedsites.com/techconnect/2009/09/power-steering-pump-service.html
Since I run hydroboost, my plan is just to drill out the fitting. In theory it should all work and even if I screw everything up, I can always get another fitting for cheap.
With the availability of a bracket soon, it will make more sense to use these Type II pumps on our Mopars
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: RylisPro] #1693441
01/21/15 12:38 AM
01/21/15 12:38 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Just an fyi, I have 4 brackets made to adapt these to a Gen III either by itself are as a complete kit with bolts and the right pulley for LX front covers. I also have a BB bracket and aluminum V belt pulley setup as well. PM with any questions. Not making a killing at all just want to get Mopar guys some good stuff to run on these hot rods. Alex,Brian and Ariel are all gonna use one so far so I figured I would get the word out that more are available.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693442
01/21/15 01:17 AM
01/21/15 01:17 AM
USA
Consulier Offline
Consulier  Offline
USA
PM some details, I'm interested in a Gen III and the Big Block setup. I wouldn't mind having spares for the Dart in case I ditch my manual box and the Satellite could stand to drop a couple pounds too.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693443
01/22/15 01:50 AM
01/22/15 01:50 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I made the KBC Bracket work on my 360. Had to customize a spacer but it was not the hardest bracket I had to make on this car.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: finadk] #1693444
01/22/15 04:04 AM
01/22/15 04:04 AM
So Cal
So Cal
Very nice.
Thank you for the detailed pictures.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693445
01/23/15 11:49 PM
01/23/15 11:49 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I got 72Swinger's power steering bracket and its a nice piece. I opted to get mine in raw aluminum so that I could drill more holes into it. I think I will drill a hole for the center mounting point so that it can be supported from the back side
One of the holes is 5/16 coarse thread and since my pump uses 8mm x 1.25 bolts I will have to drill out the mounting holes to fit a bolt long enough since all of the 3 inch grade 8 bolts at the local hardware was not threaded all the way. I am guessing the OEM bolt is not threaded all the way either. No big deal.
I'm glad I got the bracket. It's simple enough to make but, spending the time to get the material, cut, drill and design my own bracket would have cost way more than what I paid
Thanks Emil!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: RylisPro] #1693446
01/24/15 12:51 AM
01/24/15 12:51 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You can go ahead and add an extra bolt if you want but I don't think it is necessary at all. All of the force on that pump is pulling it toward the bolt you are wanting to add. On top of that every circle track pump I have seen only uses the 2 I do as well. The pumps sit flat against the bracket and have no way of wiggling. Feel free to do whatever you want with it, but from what I have seen you will not gain anything.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693447
01/24/15 10:28 PM
01/24/15 10:28 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
someone should make an aluminum bracket for this pump on a big block and sell it here to us on moparts! whats the lbs difference between this and a saginaw with an aluminum pully?
Page 2 of 3 1 2 3
