Page 2 of 4 1 2 3 4
Re: 340's Rule, 360's Drool !! [Re: Dean_Kuzluzski] #1692810
10/31/14 04:47 PM
10/31/14 04:47 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Gonna be a loooooong winter.
If the 360 ever came with a forged crank (production) it would be a total slamdunk.
Yea, tell that to the Stock and SS guys. Cast cranks are lighter, and if they can live in a low 10 second SS/JA environment, they'll live anywhere properly machined and built.
Re: 340's Rule, 360's Drool !! [Re: Brian Hafliger] #1692811
10/31/14 04:50 PM
10/31/14 04:50 PM
cudadoug Offline
cudadoug  Offline
Until you sonic test a 340 and realize they can be paper thin!
To your point: I have 2 of each in stock. 69 and 71 340. 71 and 74 360. Guess which 2 sonic check better? That's right...the 2 360's.
Re: 340's Rule, 360's Drool !! [Re: cudadoug] #1692812
10/31/14 05:00 PM
10/31/14 05:00 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
This is just like 10+ years ago!! LOL!!
Re: 340's Rule, 360's Drool !! [Re: STEFF] #1692813
10/31/14 08:17 PM
10/31/14 08:17 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Had a 372" 360 based engine 10 years ago, ran 10.98 NA on pump gas in a 2800# 69 Dart.
IIRC it was based on a very early production 360 block that apparently used the outgoing 340 core, so it was 4.00 bore (stock) but had tons of meat to work with, and was .70 over (or think of a 340 @ .30 over). Crank was internally balanced, knife edged, .600~ lift solid cam, "super stock prepped" rods. Mopar M1 and holley 750 DP.
I was a 340 guy but thought of it as the best of both.
Re: 340's Rule, 360's Drool !! [Re: SRT6776] #1692814
10/31/14 09:36 PM
10/31/14 09:36 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
You sea level(ish) guys got it good. NA small blocks see the 10s up here too. It's just not as easy.
Re: 340's Rule, 360's Drool !! [Re: STEFF] #1692815
10/31/14 10:52 PM
10/31/14 10:52 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Arguing about which SB is better is like arguing if Syphilis or gonorrhea is better...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 340's Rule, 360's Drool !! [Re: W.I.N. Racing] #1692816
11/01/14 12:07 AM
11/01/14 12:07 AM
utica ny
meus31 Offline
meus31  Offline
utica ny
What he said
Re: 340's Rule, 360's Drool !! [Re: meus31] #1692817
11/01/14 12:52 PM
11/01/14 12:52 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I`ve had numerous 340 combos in my Dart and ran good with them , but my current 360 combo is the fastest of all of them, I am making more power with less compression and cam than I ran in the 340. But then it could be my combination. My new almost complete combo: R3 based 408 with Indy 360-1 heads / pump gas combo I am hoping makes even more power.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: 340's Rule, 360's Drool !! [Re: 11secdart] #1692818
11/01/14 01:00 PM
11/01/14 01:00 PM
Finally a HUSKER again
Moparnut426 Online content
Moparnut426  Online Content
Im an odd duck, I like them all, all have their good and bad.
From the 273 up to the 360. I can tell ya my 408 pulls like a train, and revvs pretty darn good for a long arm engine.
Re: 340's Rule, 360's Drool !! [Re: HotRodDave] #1692819
11/01/14 04:13 PM
11/01/14 04:13 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Also the 360 mag has a stronger block and a hydro roller cam you can get reground to a real nice cam under $100. How much does it cost to put any roller cam in a 340?
It's been a while since I looked into it, but I came to the conclusion I could have:
a converted 340 roller,
or
a factory 360 roller that I could spend $1100.00 on head work.
Mo' Farts
Moderated by "tbagger".
Re: 340's Rule, 360's Drool !! [Re: ademon] #1692820
11/01/14 04:18 PM
11/01/14 04:18 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I have 3 standard bore 340 blocks under the workbench. Haven't had the erge to collect 360's
I also have 3 under my bench
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: 340's Rule, 360's Drool !! [Re: 65signet] #1692821
11/01/14 04:31 PM
11/01/14 04:31 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have had both, my 340 ran good but my 360 is faster. It should be though it has better everything in it.
My car was an original 340 car and that is stated on the hood plates. I often get asked what size motor and when I say 360 I get an odd look sometimes followed by "them 340s sure did run" I usually agree or depending on the person I will say yeah, but a 360 is bigger lol.
As far as the cast vs forges crank argument. Its well known that forged is better and I won't and can't argue thats it not. However I have broken a 340 crankshaft and my 360 crank was still alive when the thrust got eaten.
The 360 brings the cheap though no doubt. Mine wiped the thrust out 9 days before drag week this year. I bought a machined crankshaft and bearings kit from O'rielly auto for $188, and had it in less than 24 hours. It made the drive and is still together sofar lol.
68 Barracuda Formula S 340
Re: 340's Rule, 360's Drool !! [Re: STEFF] #2722121
12/06/19 08:30 PM
12/06/19 08:30 PM
B-Body Bull Offline
B-Body Bull  Offline
Originally Posted by STEFF
Pull this topic out of mothballs!! This is an oldie but goodie topic that used to get plenty of blood boiling!! 340 based Small Blocks will always reign supreme as the Tru HiPo Small Block, Where as the 360 based Small Blocks were nothing but 340 Wannabe's!!
Let the fight begin!!
shruggy whistling wave
Re: 340's Rule, 360's Drool !! [Re: STEFF] #2722138
12/06/19 09:29 PM
12/06/19 09:29 PM
Do you want to race your 340 against one of my 360 whistling stirthepot devil
Re: 340's Rule, 360's Drool !! [Re: Cab_Burge] #2722212
12/07/19 01:14 AM
12/07/19 01:14 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
340's.... you all are talking a 273 with a 4.125 stroke crank, right??? I bet you could take a lot of weight out of that crank during balancing.... wink
I bet a 318 with a 4.125 stroker crank (396) will stomp most Chev 396's.....
I have a 410 5.9 in the works.....
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 340's Rule, 360's Drool !! [Re: Dave_J] #2722228
12/07/19 08:55 AM
12/07/19 08:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
360 wasn’t nothing but a truck motor....
Re: 340's Rule, 360's Drool !! [Re: J_BODY] #2722338
12/07/19 04:21 PM
12/07/19 04:21 PM
gregsdart Offline
gregsdart  Offline
For a street strip cheap build it would be hard to beat a 360 magnum with a reground cam. And a .030 set of pistons with EQ heads. Those heads really move some air with a little work. 400 to 450 hp depending on what you budget for valvetrain upgrades. If i ever do another 5.9/360 it will retain the stock rockers and lift will max at about .520 but still ought to make 425 hp?
Re: 340's Rule, 360's Drool !! [Re: Mr340] #2722340
12/07/19 04:26 PM
12/07/19 04:26 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Originally Posted by Mr340
Quote
There's nothing magical about a 340. I'd rather start with a 360. More plentiful, less expensive. 20 more cubes is a bonus.
Put a 4" stroke in a 340 and 360 and which is bigger now???
<img src="/ubbthreads/images/graemlins/punkrocka.gif" alt="" />
Exactly. And anyone with a 340 block or parts wants beaucoup bucks for them just because they are what they are. I have a stroked 360 to 410 cubes that's a beast! Torque monster.
Facts are stubborn things.
Re: 340's Rule, 360's Drool !! [Re: gregsdart] #2722341
12/07/19 04:26 PM
12/07/19 04:26 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
The biggest difference in stock form, 340 ... pre EPA, 360 ... post EPA
twocents
72 Plymouth Roadrunner 11.08@123.25
Re: 340's Rule, 360's Drool !! [Re: Roughbird72] #2722343
12/07/19 04:30 PM
12/07/19 04:30 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
[quote=Roughbird72]The biggest difference in stock form, 340 ... pre EPA, 360 ... post EPA
:What does that have to do with an engine you are going to modify. You got me scratching my head on that one.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Page 2 of 4 1 2 3 4
