Page 1 of 4 1 2 3 4
340's Rule, 360's Drool !! #1692790
10/31/14 12:19 PM
10/31/14 12:19 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Pull this topic out of mothballs!! This is an oldie but goodie topic that used to get plenty of blood boiling!! 340 based Small Blocks will always reign supreme as the Tru HiPo Small Block, Where as the 360 based Small Blocks were nothing but 340 Wannabe's!!
Let the fight begin!!
Re: 340's Rule, 360's Drool !! [Re: STEFF] #1692791
10/31/14 12:31 PM
10/31/14 12:31 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
You either have a 340 or want a 340.
Re: 340's Rule, 360's Drool !! [Re: STEFF] #1692792
10/31/14 12:35 PM
10/31/14 12:35 PM
USA
hudsonhornet7x Offline
USA
Where does the Gen III fit in? lol
Steff you have a pm
Re: 340's Rule, 360's Drool !! [Re: hudsonhornet7x] #1692793
10/31/14 12:51 PM
10/31/14 12:51 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
What if you have both?
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: 340's Rule, 360's Drool !! [Re: herkamer] #1692794
10/31/14 01:21 PM
10/31/14 01:21 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
There's nothing magical about a 340. I'd rather start with a 360. More plentiful, less expensive. 20 more cubes is a bonus.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 340's Rule, 360's Drool !! [Re: DusterDave] #1692795
10/31/14 01:37 PM
10/31/14 01:37 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
If the 340 was so great why did Mopar can it and continue building the 360 in the middle 70s...?
Tony
70 AARCuda Vitamin C
Re: 340's Rule, 360's Drool !! [Re: DusterDave] #1692796
10/31/14 01:38 PM
10/31/14 01:38 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Put a 4" stroke in a 340 and 360 and which is bigger now???
Re: 340's Rule, 360's Drool !! [Re: DusterDave] #1692797
10/31/14 01:38 PM
10/31/14 01:38 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
Twenty more cubes and a longer stroke. Simple as that. If you intend to stroke it the 340/360 debate is a moot point. So says this 340 owner.
Re: 340's Rule, 360's Drool !! [Re: 70AARcuda] #1692798
10/31/14 02:28 PM
10/31/14 02:28 PM
Locomotion Offline
Locomotion  Offline
I'm not siding with the 340, but it's my understanding that it was discontinued in favor of the 360 for emissions reasons. Smaller bore produced less emissions with a more complete burn.
'73 340 vs '74 360 is the best comparison. Only bore & stroke is different & 360 wins. Only other variables would be state of tune and the rest of the car. 340's do like a little more gear, but I can't see that being a dominant factor.
Re: 340's Rule, 360's Drool !! [Re: STEFF] #1692799
10/31/14 02:29 PM
10/31/14 02:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
360s belong in vans and 340s in muscle cars is the way I see it.
Re: 340's Rule, 360's Drool !! [Re: Challenger 1] #1692800
10/31/14 02:36 PM
10/31/14 02:36 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Gonna be a loooooong winter.
If the 360 ever came with a forged crank (production) it would be a total slamdunk.
Re: 340's Rule, 360's Drool !! [Re: Dean_Kuzluzski] #1692801
10/31/14 02:44 PM
10/31/14 02:44 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I have 3 standard bore 340 blocks under the workbench. Haven't had the erge to collect 360's
Re: 340's Rule, 360's Drool !! [Re: 70AARcuda] #1692802
10/31/14 03:01 PM
10/31/14 03:01 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Your going to have a mighty long list of stupid things mopar has done of you want to go there.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 340's Rule, 360's Drool !! [Re: ademon] #1692803
10/31/14 03:02 PM
10/31/14 03:02 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I have the same...the 340s I have collect dust while the 360s are being used for racing.
Re: 340's Rule, 360's Drool !! [Re: TheOtherDodge] #1692804
10/31/14 03:31 PM
10/31/14 03:31 PM
Holly/MI
Holly/MI
I have more 360's vs 340's since they were given to me!
Re: 340's Rule, 360's Drool !! [Re: Dean_Kuzluzski] #1692805
10/31/14 04:15 PM
10/31/14 04:15 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would love to see someone bolt a bone stock hi-po 340 on a dyno with an air gap intake and TTI headers, then strap an air gap on a 360 magnum and the same TTI headers and watch the 360 make more power at EVERY RPM.
The 73 340 VS 74 360 is also a great example, when outfitted the same way the 360 puts the hurting on it real bad.
Also the 360 mag has a stronger block and a hydro roller cam you can get reground to a real nice cam under $100. How much does it cost to put any roller cam in a 340?
I have a real nice 71 340 with a fresh .030 bore job that I am gonna pass on building for my R/T Dak because I want to make 550-600 HP that will last a long time. It is a tough decesion because of the cubes I will give up but 8 cubes is nothing compared to a roller cam and a more solid block
The 360 wins in every case except a numbers matching gold restoration type build.
Re: 340's Rule, 360's Drool !! [Re: Dean_Kuzluzski] #1692806
10/31/14 04:15 PM
10/31/14 04:15 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
This topic is a failure unless we start considering the pinionangle.
Re: 340's Rule, 360's Drool !! [Re: Dean_Kuzluzski] #1692807
10/31/14 04:19 PM
10/31/14 04:19 PM
SoCal
Brian Hafliger Offline
SoCal
Until you sonic test a 340 and realize they can be paper thin!
Brian Hafliger
Re: 340's Rule, 360's Drool !! [Re: STEFF] #1692808
10/31/14 04:25 PM
10/31/14 04:25 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
But either one equipped with a long arm trumps them both,....
Keith
Re: 340's Rule, 360's Drool !! [Re: Brian Hafliger] #1692809
10/31/14 04:41 PM
10/31/14 04:41 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
ya my machinist said he likes to go .020 over on 340's if it will clean up at that.
Page 1 of 4 1 2 3 4
