Page 2 of 3 1 2 3
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692593
11/01/14 07:11 PM
11/01/14 07:11 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Regarding the LCA's,
Has anyone but me ever just drilled a couple holes and then bridge the LCA's perpendicularly with cross bolted steel sleeves? Its real easy and adds nearly (though not quite as much) as much strength as welding them with plates. Not everybody had access to a machine shop to fab the plates.... or a welder, not 20 yrs ago, and not in my garage anyway.
Its also a fairly common 'backyard' hop up on gm and ford cars with stamped U type lower trailing arms to add torsional rigidity, dead simple fix with a drill and about $5 worth of materials
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692594
11/01/14 07:13 PM
11/01/14 07:13 PM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
I basically want a sub 3000 pound 66 wagon with the best overall handling and braking using (primarily )OEM-sourced parts and assuming 15" Max wheels (15 x 8 cop wheels most likely). Only exception may be the rear brake discs which I'll probably do a Dr diff kit.
Probably 11.75" Cordoba rotors, 340 A body .870 torsion bars (or slightly larger since I've got some fatter tires), XHD (340) springs in back with bolt on swaybars.
This is not gonna be a drag car, I want this one to drive and drive often. 5500 max RPM, 10:1 and "only" about 525 hp with crushing torque curve all through the powerband. 3.23 or 3.55 gears, shift kit. Motor is already sorted and ready to go.
So basically I want a slightly improved police type ride in a ~1000 pound lighter and better weight distributed package.
The cop car wheels are really heavy, probably not the best choice for handling. They are probably a good choice if you are going to hop curbs or drive through potholes.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: RichV] #1692595
11/01/14 07:20 PM
11/01/14 07:20 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
LOTS of potholes in Seattle.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: amxautox] #1692596
11/01/14 07:32 PM
11/01/14 07:32 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692597
11/01/14 07:36 PM
11/01/14 07:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Seems like a good idea for the guy without access to a welder or knows someone with a welder.
I don't weld. But I just got these 1" wide steel strap and braced mine. No added weight for overlapping metal and I didn't want them too obvious. Thought about sinking the ones on the bottom 1/2" or so you couldn't see them well.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: autoxcuda] #1692598
11/01/14 07:42 PM
11/01/14 07:42 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
This is something I've never thought of. I saw Jim Lusk's YouTube video of the DIY lower control arm mod.
http://www.youtube.com/watch?v=Nwes-SP8u4w
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: dart4forte] #1692599
11/01/14 07:48 PM
11/01/14 07:48 PM
Weddington, N.C.
Weddington, N.C.
@ dart4forte,
Thanks for that link! Very cool car, I forwarded the link to Stephen to check out.
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692600
11/01/14 08:34 PM
11/01/14 08:34 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
@ dart4forte,
Jim is actually are pretty talented guy with lots of A body experience. Drop him a line and pick his brain.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692601
11/02/14 04:00 AM
11/02/14 04:00 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Planning on body color cop wheels with dog dishes
Wize, this wagon is going to be sooooo cool!
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692602
11/02/14 01:27 PM
11/02/14 01:27 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
And I quote "Monkey see, monkey do"
Its not a problem that needs to be solved, and no one on this site on their best day could notice an improvement by this mod, or substantiate a failure w/O it.
Want a banana?
I am also leery of usefulness of "bone crushing" torque in a relative light stock suspension 15"x8 tired car on the street. HP yes.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: jcc] #1692603
11/02/14 01:55 PM
11/02/14 01:55 PM
Weddington, N.C.
Weddington, N.C.
JCC,
I'm looking for a specific power/torque curve for the combo, I've had big block powered A body cars that were a blast to drive straight but were extremely (as you can imagine) nose heavy. The small block and the wagon body combined with at least 250/300 pounds less weight should help offset that a lot.
And i agree that the gusseted LCA's probably dont do much with an otherwise stock suspension (modt notably OEM rubber bushed) Mopar, but if it may help any at the limit to me it's worth trying.
As for bone crushing torque in a light car, I have a 427" stroker small block in a 2400 pound Cobra....and for years I rode a Yamaha V-Max.....it's certainly not everyone's cup of tea, but the adrenaline rush of power oversteer works for me. If i owned a road race course i would probably prefer a smaller, higher winding motor better balanced chassis combo...so I do understand and respect your point.
I'll pass on the banana though, I reckon the wagon's got enough yellow as it is!
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1692604
11/03/14 11:15 PM
11/03/14 11:15 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have discovered that all my customers are happier with way to much TQ. Me too!
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: HotRodDave] #1692605
11/03/14 11:18 PM
11/03/14 11:18 PM
amxautox Offline
amxautox  Offline
Torque gets you moving. By the time you get to the next traffic light the horsepower is barely kicking in, maybe.
Tom
author unknown
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: amxautox] #1692606
11/04/14 07:46 AM
11/04/14 07:46 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Torque with out adequate traction moves little but the excitement meter.
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: jcc] #1692607
11/04/14 07:21 PM
11/04/14 07:21 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Knowing that your tires are the limiting factor rather than engine performance is much more, let us say; exciting...
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: BigBlockMopar] #1692608
11/04/14 07:33 PM
11/04/14 07:33 PM
Weddington, N.C.
Weddington, N.C.
I'm thinking 26" x 9 Hoosiers could help sort out the traction at the drag strip, I could use hoosier road race type compounds for twisties, and either way the wagon body will help it hook considerably better than a sedan body.
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1876666
07/23/15 05:29 PM
07/23/15 05:29 PM
Weddington, N.C.
Weddington, N.C.
Quick update on the wagon, a SLIGHT departure on the 15" cop wheels, lol
You can see the car's coming along there's a thread in Race only about it
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1876676
07/23/15 05:43 PM
07/23/15 05:43 PM
Weddington, N.C.
Weddington, N.C.
WIZE
In Car:
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: Streetwize] #1876868
07/23/15 09:42 PM
07/23/15 09:42 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I like it alot Wise.
Mopar to the bone!!!
Re: 66 valiant Wagon 440 W2 - Best handling OEM based parts [Re: 72Swinger] #1877171
07/24/15 12:08 PM
07/24/15 12:08 PM
Weddington, N.C.
Weddington, N.C.
Thanks,
for right now I think I'll just go with the 340 .87 T bars , a pair of Helwig bolt-on sways, XHD springs and a good set of Bilstiens. I can always upgrade once it's on the road, I want a decent ride for now until I see how the reinforced chassis deals with all the 440" W2 torque. I don't want a super stiff slot car ride, I want it to feel balanced, as light and nimble as I can without killing the ride.
WIZE
In Car:
Page 2 of 3 1 2 3
