Re: coil over front on a duster?
[Re: BobsProFab]
#169075
12/28/08 05:46 PM
12/28/08 05:46 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
HEY BOB, how much on the shock's ????
just shocks or complete with springs and hardware.
these are sold as a shock ready for coil overs. must buy the hardware kit also to install the spring.
Do you sell the aluminum piece that replaces the bottom rubber/poly bushing on the top shock mount?
[Re: mopowers]
#169076
12/28/08 06:50 PM
12/28/08 06:50 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
i turn them on the lathe out of 6061, the urethane bushing that comes with the shocks will not hold the weight when converted to coil over. they are fine for using them as a stock style front shock. I make them as needed, but if you need a set i can tool some up ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Hot 340]
#169078
12/28/08 08:57 PM
12/28/08 08:57 PM
BobsProFab
sycamore,ohio
Yes, i put a ton of street miles on 340Ricks challenger this past summer (i think i put more miles on his car than he did in the past 10 years ![](/ubbthreads/images/graemlins/biggrin.gif) ) with my setup on it and the same coil overs with #250 springs ![](/ubbthreads/images/graemlins/thumbs.gif) the lighter spring seems to work well with me adding more per load to them for better reaction from the suspension. i can get you awesome deals on AFco products ![](/ubbthreads/images/graemlins/wave.gif) Bondo
[Re: BobsProFab]
#169079
12/28/08 09:50 PM
12/28/08 09:50 PM
BobsProFab
sycamore,ohio
3850M list 410.40 each : T2 5 inch drag coil over ready shock double adjustable. 23250CR list 68.69 each : coil over spring, this is what i run on Ricks car. 20124 list 47.55 each : coil over hardware kit. 20144 list 40.10 pair : bearing kit. thats $1,093.00 list on the front coil overs www.afcoracing.com and search the part #'s they are not cheap but one of the best shocks on the market today and AFco's customer service is second to none ![](/ubbthreads/images/graemlins/thumbs.gif) you can PM me for a killer price on a set ![](/ubbthreads/images/graemlins/wave.gif) Bondo
#169080
12/29/08 02:54 PM
12/29/08 02:54 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
thanks, I also saw somewhere welding done on the LCA,s is this necessary?
Right here. Coil Over Conversion
Ok I missing the boat here ! if you weld them LCA like that pic..how do the control arms move up and down ??
[Re: dizuster]
#169083
12/29/08 06:36 PM
12/29/08 06:36 PM
BobsProFab
sycamore,ohio
yes the LCA will try to bind. but on a budget it gets the job done. my setup has zero resitance ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Plumb Wired]
#169085
12/29/08 11:42 PM
12/29/08 11:42 PM
mopowers
Sac, CA
The part you see welded is the adjuster that is no longer used once the torsion bar is eliminated. The weld just keeps what's left of the adjuster from moving around. I have whacked them off as close as possible then welded just for cosmetic purposes. Has nothing to do with the movement of the LCA.
Mike Gray
I think the confusion lies with the bolt and big washer that connects the LCA to the pivot pin. Once the adjuster is welded to the LCA and the pivot is bolted to both the LCA and the K-member it doesn't look like it should move.
It looks like Duster Dave used a nylon or teflon washer to allow the LCA to rotate up and down a little easier. It looks like that would free up some of the movement.
