Re: early 60s/ late 60,s 318 [Re: dogdays] #1690590
10/28/14 08:51 PM
10/28/14 08:51 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
More deck height
Re: early 60s/ late 60,s 318 [Re: dogdays] #1690591
10/28/14 08:56 PM
10/28/14 08:56 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Gary Pavlovich and friends are coming out with a new poly intake, I have a poly in my 67 Valiant, it has a Scnieder cam, slightly ported heads and a factory four barrel intake with an AVS carb and factory chrome valve covers, it runs great!, has tons of torque and would no doubt do better if I could shoehorn a set of headers into the A-body
The engine is soon to be replaced by a W2 340 though, this engine will be for sale for $500 less dist. and carb.
Joey
Re: early 60s/ late 60,s 318 [Re: jake4cars] #1690592
10/29/14 02:50 PM
10/29/14 02:50 PM
dogdays Offline
dogdays  Offline
Deck height between the Poly 318s and the LA318s that came right after them are the same, 9.600". Late 318s, like my '86, have a deck height of 9.577 or 9.578.
For years, the cheap trick for higher compression 318s was to substitute the Poly pistons for LA pistons. They had a comp height of 1.81. But the KB167 LA 318 piston has a comp height of 1.807 or something like that. The deck heights for the two engines are the same.
R.
